Old 02-23-2008, 03:28 AM   #1
vroomazoom
Default Maiden flight/Break-in
S W E E T ! Why was I flying the 450 all this time? This 600n pro kit is just awesome. Just curious on how much tanks is everyone else going through before tweaking a little more HP out of this OS 50 Hyper? Please give me your opinions.
vroomazoom is offline        Reply With Quote
Old 02-23-2008, 08:40 AM   #2
freeflyn2001
I only have one tank on mine, going to finish the breakin today. I personally would run 3 to 4 tanks rich leaning it out a few clicks at a time.
Trex 600 Pro--8V system--JR 8717's--Spartan DS-760 S9254----CSM Revlock20. OS Hyper Hatori Pipe--Carbsmart--- DX7 AMA-896424
freeflyn2001 is offline        Reply With Quote
Old 02-23-2008, 09:31 AM   #3
TheBum
I'm planning to maiden mine this weekend. I plan to put about 4 tanks through it to break it in. I've heard a good way to do a quick break-in is to alternate between hovering and landing/idling.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is offline        Reply With Quote
Old 02-23-2008, 12:18 PM   #4
Street Flyer
I went a little over board and used a whole gallon to break in mine.
t-rex xl cde
t-rex se V2 with scorpion -8
t-rex 600n
t-rex 700n
Street Flyer is offline        Reply With Quote
Old 02-23-2008, 12:25 PM   #5
Walker76
I'm starting to lean it after 5 tanks on the rich side.
Walker76 is offline        Reply With Quote
Old 02-23-2008, 02:18 PM   #6
Bobbyk
Location: Born in London, Live in ATL, Heritage from Ghana
Welcome aboard guys, you made the right choice, if you have somewhere to fly it you will not fly anything else, I just leave it in the car and only bring it in to charge the lipo.
4-5 tanks is about it and take it easy.
Robert
<<< Ashlyn, daddy loves you more than his heli's, don't mind mummy >>>
<<< ..............MA Spectra G (Supporting Made in USA), DX7.............. >>>
Bobbyk is offline        Reply With Quote
Old 03-02-2008, 10:12 PM   #7
e46mpower
Wassup Vroomazoom, I just picked up a 600 Nitro from Alohas too...Finished building her, but waiting on the gyro, servos and the gov too...do you fly with Sheldon at Halawa Park too?
JR x9303-sold
Align TREX 500 CF-sold
Align TREX 600 Nitro Pro-for sale. $500
e46mpower is offline        Reply With Quote
Old 03-03-2008, 01:50 AM   #8
aussiemick
I had 1 1/2 turns for the first 4 flights then wound the needle valve in 2 clicks per flight till I got to a little bit less than 1 1/4 turns. I can still keep my finger up the bum end of the engine for ages it is only a few degrees warmer than ambient, I can probably lean it up a bit more yet.
I have subsequently turned the low end in about 10deg to help in winding up to speed.
Mick
aussiemick is offline        Reply With Quote
Old 03-09-2008, 04:16 AM   #9
vroomazoom
Sometimes I go to Halawa, but mostly at the Kawainui Swamp. I fly airplanes too.
T-Rex 450 SE (My Edition)
T-Rex 600n Pro, OS 50 Hyper, GY611, MultiGov, Align Pipe, Spectrum DX7
Old 03-09-2008, 05:37 PM   #10
Mercuriell
The OS HYper 50 being a ringed engine doesn't need long breakins like non ringed piston engines - just time for everything to bed in - I reckon about 4 tanks rich on ~ 1 1/2 needle turns - check the head temp (<90C) then start leaning up a click at a time.
John
Mercuriell is offline        Reply With Quote
Old 03-09-2008, 08:00 PM   #11
Shakes268
Finally got mine out of the way today. 5 tanks through it. Love it!! Everything worked great, no issues.
Shakes268 is offline        Reply With Quote
Old 03-09-2008, 08:03 PM   #12
manike
What head temp shows you are at the right point with the engine?
I'm probably at 12-15 tanks now and still running rich. I have a slight hesitation at spool up, but otherwise runs and flies great!
manike is offline        Reply With Quote
Old 03-09-2008, 09:27 PM   #13
vroomazoom
Just curious at what kind of gov is everyone using and whats your headspeeds that you set up for? With that in mind, whats your flight times at?
I'm using a Multigov and its set up at the default settings which is 1800 for normal and 1900 for idle up, my needle is at 4 clicks leaner from 1 1/2 turns out, on my 7th tank and having 8 minutes flight time in just forward flight (feeling my heli out first before attempting 3d). My buddies suggested using 2150 for idle up.
Old 03-09-2008, 09:35 PM   #14
Shakes268
Pretty much same as you. Multigov with the normal mode set up as a limiter, 1800 RPM.
5 tanks through it, just hovering and I was getting around 8 minutes or so but I'm still fairly rich.
I have not done any FF with it but my multigov is set up for 1900 in idle 1 and 2050 in idle 2.
