Old 02-24-2008, 11:16 PM   #1
JASON671
Question is 3s 2100mah 18c enought for the trex se v2?
looking at buying a couple extra bats. just wanted to know if 3s 2100 18c will handle the stock trex v2/ 430xl...stock esc...hs65mgs...s9650...12t pinion??thanks
MA FURION 6 VBAR!!!
MSH MINI PROTOS VBAR
JASON671 is offline        Reply With Quote
Old 02-24-2008, 11:56 PM   #2
TGibe
I would imagine it depends on your flying style. For simple sport flying that should be fine, but it you go to 13T, 100 flat throttle, and start throwing it around the 18C rating might not cut it.
I would suggest the Kong Power 2200mAH 25C packs. They are a good price and give you room to fly hard if you want... I do simple forward flight with them and they just barely get warm...
"The Grass Is Brown Everywhere"
- TREX500 AR7000/3xHS5245MG/GY401&9254/500L/12T/Align 425CF/Align 6S2600mAH(x5)/DX7
- Blade mCX just to torment the family pets
TGibe is offline        Reply With Quote
Old 02-24-2008, 11:56 PM   #3
blueprint
it'll work.
i use TP 3s 2100 15c prolites and i've had these packs for over a year now with no problems. i do recommend cutting the flight times short though. i can get a solid 4 min. 25 sec. on these packs.
blueprint is offline        Reply With Quote
Old 02-25-2008, 12:01 AM   #4
DominicD
The Capi - HF Support
18C with a 2100mah is a continuous 37.8A. If your using a 35A esc .............
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is offline        Reply With Quote
Old 02-25-2008, 12:19 AM   #5
TGibe
I just checked my last 10 flight logs from my eagle tree logger and my high amps was only 30.05 and that was just a quick spike. Average amps are much lower...
Old 02-25-2008, 12:44 AM   #6
helijack
I'm using ParkZone 2200mah rated at 12C. So far so good.......but I just do light stuff anyway. Nothing fancy.
T-Rex 450 SE V1, HS65MG, 9650, 325 CF, AR6100, 2200 FlightMax, 430XL/BL35X, GY401 ...SOLD
T-Rex 500ESP...SOLD
DX7...Still for sale
M.A.A.C. 78596
Ex President - Calgary RC Heli Club
helijack is offline        Reply With Quote
Old 02-25-2008, 12:51 AM   #7
kamtsa
They work for me. I am using these ones http://www.fmadirect.com/Detail.htm?...210&section=69 150g, $50, and they perform just like the TP's.
Kam
kamtsa is offline        Reply With Quote
Old 02-25-2008, 09:13 AM   #8
TGibe
Kam
Interesting... I have been looking at the Cellpro batteries as well as a more cost effective option...
