Hey everybody. I am not going to bore everyone and expect them to take 45minutes+ to explain it. And I am sure it has been discussed time and time again on here. I have a T-rex 450 SE V2 with the following: Stock Motor, ESC, Spektrum DX7 with AR7000 RX GY401 Gyro, and JR Servo Kit. I am in the process of building the bird now and I'm having a blast. I can't wait to build a 600! But anyway, If anyone knows or has the link to set up a DX 7 with similar if not identical set-up I will be running I appreciate it! Thanks.
Sponsored by Visa/MasterCard / Team Budweiser / Trojan Field Rep Donut Connoisseur To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. HELI-FREAK, You couldn't have picked a better place to land ! |
Jermo's DX7 setup video. Just do what he did.
http://www.helifreak.com/showthread.php?t=28681 Before you set subtrims and trim your servo horns make sure they are moving the right way. When you install your gyro make sure you have your rudder trim center, your throttle at the low position and then rebind! One thing Finless doesn't mention is. Set your Idle2 pitch to 0, 50, 50, 50, 100. Now you are sure you are at center stick. Get your swash 10mm high at center stick. Then set your idle2 pitch back to 0, 25, 50, 75, 100 Here's Finless's videos. ![]() http://www.helifreak.com/showthread.php?t=11373
Field Representative for To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
