Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > King II/III/IV and CP 2/3
King II/III/IV and CP 2/3 E-Sky King 2, 3, 4 plus CP 2 & 3
Old 03-11-2008, 06:52 AM   #1
TommyVuitton
Default HBK2, DX7 and a GY401
Ok, so my rudder servo stopped working. And while i wait for my trex to land (over 2 months now!) i decided to install the electronics that were intended for the trex. Put HS65s on the cyclic, a GY401 and a S9650 on the tail. What a difference! Anyways, i have set it up best i can but i have a few problems that need addressing:
1. When i pitch up on the cyclic the servos move at different speeds which causes a "wave" effect.
2. Since switching on Gyro Sensing on the DX7, the heli only seems to be operating in AVCS mode. I swich the gear channel and the light on the gyro stays on.
Appreciate any help!
TommyVuitton is offline        Reply With Quote
Old 03-11-2008, 07:03 AM   #2
capebob
I can't help with the different servo speeds. Sounds like a bad servo, but I'm not sure.
Unfortunately, when using the Gyro Sens. page the gear switch is not one of the available options to operate your gyro. You are limited to using either the flight mode switch or the throttle hold switch, both of which have serious drawbacks. The easy solution is to not use the gyro sense page. Set your gyro up on channel 5 and use the gear switch to control the gyro. It works great and allows changing gyro modes without changing flight modes or going into throttle hold.
Bob
Samuel Adams field rep
Buffalo Wings field rep
Success is the ability to go from one failure to another with no loss of enthusiasm.
Churchill
capebob is offline        Reply With Quote
Old 03-12-2008, 12:42 AM   #3
damyxz
The hitec servos move opposite the stock servos. Changeup your srvo setting on the reverse menu and the swash settings.
_____________________
Scott's Hobbies
DVS inc.
damyxz is offline        Reply With Quote
Old 03-12-2008, 03:55 AM   #4
TommyVuitton
Servo directions are ok, when i said that there is a wave effect, i meant that its quite small but noticable.
Old 03-17-2008, 09:34 PM   #5
Boom Operator
Hey could use some help. I have DX7 airplane version radio with an AR7000 Receiver, Esky Honey Bee King II can anyone guide me on proper radio set-up completely new to RC heli's and man am I confused! Appreciate anyones help Thanks Ed
Boom Operator is offline        Reply With Quote
Old 03-18-2008, 12:12 PM   #6
JustPlaneChris
Ed, check out Finless Bob's setup videos here in this forum. They should tell you everything you need to know!
http://www.helifreak.com/forumdisplay.php?f=60
Chris Boultinghouse
Team MSH USA | Team Lynx Heli
JustPlaneChris is offline        Reply With Quote
