Go Back   HeliFreak > R/C Helicopter Support > E-Sky Helicopters
E-Sky Helicopters E-Sky Line - Help each other out!!
Old 03-16-2008, 12:43 PM   #1
TommyVuitton
Default Slow response on GY401
Got an hbk2 with GY401 and 9650. When i am hovering and i throttle up quickly the tail lags behind (takes time to catch up to original position). Please help!
TommyVuitton is offline        Reply With Quote
Old 03-17-2008, 10:28 AM   #2
JustPlaneChris
If you are running a fairly low headspeed and stock King tail blades, the best gyro in the world won't keep the tail from stepping out as you describe. Try using Trex "batwing" tail blades first, and if that doesn't help you may need to increase your headspeed.
Chris Boultinghouse
Team MSH USA | Team Lynx Heli
JustPlaneChris is online now        Reply With Quote
Old 03-25-2008, 04:49 PM   #3
TommyVuitton
Thanks, i noticed that it would not be as bad when i swiched to 3d mode.
Old 03-25-2008, 04:56 PM   #4
TommyVuitton
I have another question, maybe you can help. I bought the full cnc upgrade for the hbk2 and while putting together the head i slightly overtightend the small screws that hold the flybar holder. One side sits good but the other wiggles and doesnt sit tight.
Old 03-25-2008, 10:46 PM   #5
JustPlaneChris
Did one of the screws strip? If it did, you may need to replace the part it threads into.
You can possibly try putting some extra loctite in the hole and let it cure overnight, but it's risky having fasteners in the head that aren't exactly right.
Chris Boultinghouse
