Old 03-19-2008, 12:41 AM   #1
Wolfpackin
Default 2,3 or 4 Shims Per Side?
My heli came with two on each side and I understand newer ones are coming with up to four.
So, for me, I'm still using +10% Expo on aileron and elevator, would adding shims be a good idea or would it just negate the Expo I'm using?
I like the idea of improving cyclic response because my heli seems mushy and there seems to be a delay when I give inputs.
What do you think, should I add a shim or two per side?
Thanks.
Wolfpackin is offline        Reply With Quote
Old 03-19-2008, 01:28 AM   #2
rudderman
I have mine set up with 3 shims on each side and it seems just right for me.
rudderman is offline        Reply With Quote
Old 03-19-2008, 06:42 AM   #3
skigolfmike
Mine came with the equivalent of 22 shims per side. I tried 2 shims and thought it was too soft. Now I'm flying 4.
skigolfmike is offline        Reply With Quote
Old 03-19-2008, 07:51 AM   #4
LockMD
mine came with 2 but after a crash and some slop and with Sokal's suggestion I have 3 per side. Feels good to me.
LockMD is offline        Reply With Quote
Old 03-19-2008, 12:53 PM   #5
Wolfpackin
Thanks for the input, guys.
For those of you that have more than 2 per side are you using any Expo or have you moved past that?
Mike,
I'm no expert so I think 22 shims would be a little stiff for me.
Old 03-19-2008, 01:38 PM   #6
skigolfmike
Originally Posted by Wolfpackin
Mike,
Was for me too - I crashed. 4 is fine for me.
On another board I think youthflier said to add shims until the head felt notchy, then back off one or two shims per side.
FWIW, I'm flying with 20% expo.
Old 03-19-2008, 01:52 PM   #7
LockMD
I actually upped my expo flying in these winds I prefer it a little sluggish current setting = 30% but on a nice day 20% feels better to me.
Old 03-19-2008, 11:08 PM   #8
rudderman
Wolfpackin
Im using the same expo that i got from you. They seem to be a perfect match.
Old 03-20-2008, 12:20 PM   #9
Wolfpackin
Rudderman,
I've changed mine a bunch of times. I'm now at 90% +10% on Aileron and Elevator.
What are you using for Dual Rate and Expo?
Thanks.
Old 03-21-2008, 12:03 AM   #10
buildem336
I put 8 shims per side and now it flys great no more wobble with side tic tocs now for some carbon main blades.
buildem336 is offline        Reply With Quote
