Old 03-27-2008, 11:19 PM   #1
Markeydoo
Default Having problems with my GYRO
I just got a used GY401 and when I throttel up and add a small amount of rudder the thing just doed pirowets on the ground. I have tried it in an off of HH and still get the same result. I slapped my old rce-500x gyro in and I don't get the uncontroalable piroweting.
I have also turned the sensitivity down on the radio and still get the same result.
Any suggestions.
Mark
Markeydoo is offline        Reply With Quote
Old 03-27-2008, 11:22 PM   #2
heliMark
HF Video Underlord
you may need to check that the gyro is opperating in the right direction by reversing the tiny dip switch on the gyro itself or in the radio. is your gyro mounted rightside up or upside down on the heli(above the boom block or under)?
M3
Mark Schneider Team Rotor Rage, YS, RC Accessory, Poweredge batteries, Perfect Regulator.
Fury 55, Trex 700, Trex 450
heliMark is offline        Reply With Quote
Old 03-27-2008, 11:26 PM   #3
Markeydoo
Under the boom. The controls seam correct, that rudder stick right nose right.
Old 03-27-2008, 11:40 PM   #4
TheBum
You need to make sure the gyro is also switched to go the right direction. With the gyro in HH mode, move the tail to the right (nose left). The blades should pitch such that their leading edges move left. If it's backward, you need to flip the reversing switch on the gyro.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is online now        Reply With Quote
Old 03-27-2008, 11:54 PM   #5
Markeydoo
I will try that
Old 03-28-2008, 12:10 AM   #6
heliMark
HF Video Underlord
yeah I believe when mounted upsidedown the gyro dip switch does need to be reversed, once you get that corrected double check the limit pot and delay pot on the gyro, delay should be 0 if your using a digital tail servo, then just find a good gain percentage and have fun
Old 03-28-2008, 12:35 AM   #7
Markeydoo
You guys are right. I mounted on the top so I could play with the switch and that worked.. Thank you Thank you Thank you
Old 03-28-2008, 04:47 PM   #8
TomRex
on top of block is bad practice unless you are prepaired for a paddle strike when you crash
How much past 200 mph do I need to go you ask?
TomRex is offline        Reply With Quote
Old 03-28-2008, 05:27 PM   #9
Dumb Thumbs
Some people happen to LIKE a good paddle stike every now & then
Dumb Thumbs is offline        Reply With Quote
