Old 04-02-2008, 10:58 PM   #1
Finless
Team Taco VP
Default Hitech HG-5000 Gyro Setup / Review
OK folks...
As part of building the BeamE4 I needed a gyro. I was at my local hobby shop (Rob's RC Hobbies) and while they they asked me if I ever did anything on Hitech's new gyro the HG-5000. I told them no but wanted to. They decided to sponsor a video on setup of this gyro right then and there and I didn't even ask! Very cool
Rob and Michelle are great people so of course I accepted EASILY. Thanks you guys!
So with that here we go... I am using this on my BeamE4 so it is using that heli for setup. Should be the same as many other 450 helis.
OK so lets get on with it. If you don't mind how about watching a little FUN and see my local hobby shop and say hello!
VIDEO LINK -> Visit to my Local Hobby Shop (12 Megs)
On with the setup vids!
VIDEO LINK -> Hitech Servo Install (27 Megs)
VIDEO LINK -> Steps 1-3 Radio type, Servo Type and Rotate Rate settings (33 Megs)
VIDEO LINK -> Steps 4&5 Servo Setup and Gyro Direction settings (40 Megs)
VIDEO LINK -> Step 6 Servo Limit Settings (24 Megs)
VIDEO LINK -> Step 7 Setting up RATE mode and final setup (34 Megs)
OK that will finish the setup stuff. I will do flight testing this weekend along with the BeamE4 flight report. I will share final setting and how I liked the gyro.
Enjoy!
Bob
"Don't Taco My Pack Dude!"
Old 04-02-2008, 11:52 PM   #2
Vinger
Thumbs up Good One
Thanks Bob, at least now the Logitech/Hitech can get a bit of fair comment. Steps4-5 file is not available! Spelling of file should be step4_5 and not sstep4_5
I get a whipping stop to the one side and a mushy one to the other side. CSM has a trick of offsetting the servo arm to one side and not 90deg as everybody preach. Here is there explanation:
Servo arm offsetting
Some helicopter tail linkage geometries give somewhat asymmetric response to tail pushrod movement with much more rapid changes in pitch occurring one way than the other. In these cases the servo throw to cover the full pitch range may be greater one way than the other. The SL720 has independent travel adjustments for the two directions to accommodate these differences. In some machines more symmetrical handling characteristics may be obtained if the servo arm is rotated around one or even two splines on the servo shaft so that it is no longer at right angles to the pushrod when the servo is centred. A change in the pushrod length will be needed to restore the 8 degrees of pitch with the servo centred. With the servo arm offset in the correct direction the servo throws will be more equal. Remember that the travel limits will need re-adjusting after this process to ensure the full tail pitch range is available.
Adjusting the Stop quality
At the initial installation you will have made sure that the servo travel limits are set so the tail pitch each way is limited only by the mechanical limits of the linkage. You will also have carried out the Quick-trim procedure and adjusted the gyro gain to the maximum that gives no wagging. Now assess the quality of the left and right stops from fast pirouettes (i.e. full stick). Note if the stops are sharp enough for your flying style and see if there is a marked difference between the two stops noting which stop is the softer. If you are trying to obtain fast stops you will find, beyond a certain point, that increasing the gyro gain has only a marginal effect on stop speed. This is because the available tail rotor authority dominates stop times from fast pirouettes. If, having optimised the gain, the stops are softer than you require you will need to increase the power of the tail rotor. Since you will already be using the maximum pitch range available increase in the tail blade length should be made. A small increase in tail blade length can make a large increase in the available thrust of the tail rotor. Longer tail blades increase the mechanical gain of the tail system so an adjustment to the gyro gain may be needed.
In many cases only one of the stops is soft. Check that the mode 0 trim is acceptable and repeat Quick-trim if needed before re-assessing the difference between the stops. A lack of tail-rotor pitch one way (usually in the leftward direction) is quite common. This shows up in slower entry into left pirouettes and slower stops from right pirouettes and can be especially noticeable with governed engine systems in low G manoeuvres (e.g. stall turns). We find that good tail performance is obtained with 45 degrees of right tail pitch and 35 degrees of left tail pitch. In extreme cases it may be necessary to increase the tail blade length until the soft stop becomes acceptable. Prevent the faster stop becoming excessively hard by a small reduction in the travel adjustment for the appropriate pitch direction.Generally this will be all that is required to obtain matched stops from all speeds. However if stops from more modest speeds of about 180 deg./s show some left-right imbalance then these can be matched by use of the stop tracking controls via the PC interface
The left and right hand stops are not equal. Stops from right hand turns are slow but clean while left hand stops are bouncy.- The mechanical tail trim needs setting correctly. Carry out the procedure in the Quick-trim section of this manual and reassess. If you still have problems, try reducing one servo travel as follows: - if bouncy when stopping left turns, reduce the right pitch travel limit and vice versa.
No more Heli Newbie
TRex 250, Trex 500GF, TRex 600ESP
DX 7 & All logitech Gyros
i1010B and MegaPower 960 Chargers
Old hand at Planks
Vinger is offline        Reply With Quote
Old 04-03-2008, 12:56 AM   #3
Finless
Team Taco VP
fixed the file name......
Thanks for sharing that tid bit! In fact I do that with a 401 to get rid of that same issue with the hard stop! Old trick from the 80 before gyro's too
Some people say NO... Don't do that but using mechanical setup to even the throw works! Take advantage of the arc of the servo arm I always say
Thanks!
bob
Old 04-04-2008, 02:10 PM   #4
Justin911
thatnks again bob... This set of vids will definately help me out.
Beam Team, DHW, Beam E4, T-Rex 500
Justin911 is offline        Reply With Quote
Old 04-04-2008, 07:48 PM   #5
psilo
Thanks Bob.
I am assuming that the Hitec is basically the same as the Logictech 2100? I am curious as on the Logictech it tells you to leave the End Points at max and use the D/R to reduce your piro rate?
Gerd
Helis:T-Rex 250 SE, T-Rex 600NSP, Synergy N9
Memberships: BMFA #162774
psilo is offline        Reply With Quote
Old 04-04-2008, 07:51 PM   #6
Finless
Team Taco VP
Well using DR is OK too... But really it doesn't matter. Lowe numbers on rudder reduce piro rate and higher numbers increase it. Using dual rate reduces when turned on so same result. I personally don't want to worry about another switch and once I get the piro rate set where I want it I never change it.
Yes the setup of ther 2100 is pretty much the same.....
Bob
Old 04-04-2008, 08:00 PM   #7
psilo
Thanks. Will be rebuilding my Belt CP soon so these videos will come in handy as I have the 2100T with the 3100G servo on there.
Old 04-06-2008, 12:34 PM   #8
Takis
Default Setup using Futaba T9CAP Tx
Hi.
Thanks for helping us.
One issue:
Using Futaba Tx, should I use Gyro mode Gy or Std?
Mix Act or Inh?
I use Mode Gy, Mix Act ,Rate Up AVC 80% and Down Nor 70%.
Should I keep it so?
Also, I think I can use rate mode to center servo. Is that so?
Best
Takis Katsoris
Takis is offline        Reply With Quote
Old 04-07-2008, 01:08 AM   #9
K27R
A couple of questions:
1. When setting up for the transmitter. The gyro directions mentions to set your limit on the rudder to 150%. In your video it looks like 100% worked, but maybe it work on peoples set up. I don't know. When I set mine up I used a X9303 and set rudder ATV, whoops thats Futaba lingo, travel adjust to 150%.
2. If you want a faster pirouette which do you do; set the travel adjust, I am getting used to my JR lingo now, to 150% or increase the Rotate Rate on the gyro?
K27R is offline        Reply With Quote
Old 04-07-2008, 01:12 AM   #10
Finless
Team Taco VP
If you watch the video again later after having to go farther out on the servo arm I tell you to set for 150 for setting limits!
Like any gyro you increase the rudder end points for faster piro.... BUT there is another adjustment called rotate rate... Now I have screwed with this adjustment both directions and I really DO NOT feel any real big difference in this setting.
Soon I will have the flying of the BeamE4 up soon and the bad news about this gyro... I don't like this gyro that well just like I didn't really like the LT2100.... The piro rate is slow even at max end points and rotate rate AND the hold is still softer than I like.
Bob
Copyright © 2004-2009 - William James - Helifreak.com
