Belt CP E-Sky Belt CP
Old 04-04-2008, 07:45 AM   #1
psilo
Default Belt CP Setup - Content from tutelar3
A heli with proper linkage setup will have:
* no binding during movement
* a linear, mirrored response from the controls over the entire positive to negative pitch range
* zero pitch at mid-stick, and the equal positive and negative pitch
* blades that track well in the full +ve and -ve range
Part 1 - Prepare to set up the linkages:
1. unplug the motor
2. power on the transmitter and heli
3. align both Paddle Control Arms horizontal on the flybar, and the paddles horizontal to the Paddle Control Arms
4. ensure your trasmitter program pitch curve is programmed for zero pitch at center and is linear both positive and negative (usually one of your Stunt modes)(0, 25, 50, 75, 100)
5. move the throttle (left stick) to the center (mid-stick) position, where zero pitch will be set
Part 2 - Set Up the linkages:
1. remove the servo arm and rotate around each spline to set the servo arm as close to 90 degrees as possible; put the screw back in the servo arm
2. use [SUB TRIM] to get the arm exactly 90 degrees
3. adjust the linkage between the servo arm and the control horn to make the control arm parallel to the servo arm
4. complete this step for all 3 servos
5. adjust the 3 linkages to the swash to ensure the swash is level
6. adjust the linkage to each Bell Mixing Arm to make it horizontal
7. if your pitch is not zero, adjust all 3 links to the swash to raise or lower it until you have zero pitch (and the same positive and negative pitch in each direction)
Part 3 - Blade Tracking tip:
With wood blades, tracking can be difficult due to shape tolerance, distortion of the plastic holder, structural clearance, etc. To make tracking easier to accomplish:
1. make an ajustable Bell Mixer Pushrod link (blade to mixing arm); leave one side with the fixed-length linkage
2. setup zero pitch using the fixed-length linkage (see part 2)
3. use the variable-length link to adjust the blade for tracking
4. if you still seem to need a 1/2 turn, adjust the Swashplate to Bell Mixing Arm linkage; do not adjust it more than 1/2 a turn
Part 4 - Signs of a good setup:
1. throttle at mid-stick with zero pitch
2. Swash Plate is level
3. Main blade Clamp is horizontal (Pitch is zero)
4. Paddle Control Arms are horizontal
5. Bell Mixer Arm is horizontal
Thank you tutelar3 for sharing your info!!
Helis:T-Rex 250 SE, T-Rex 600NSP, Synergy N9
Memberships: BMFA #162774
psilo is offline        Reply With Quote
Old 04-04-2008, 07:06 PM   #2
CodeB4U
Wow, i needed this when i first go my Belt. Awesome tips and photo's.
Edit: Just wondering, when i center my servo horns... Ok i have the TX on, have all trims centered, Do i want it in Normal mode or 3D mode? Also, do i want the throttle stick at it's lowest point or in the middle?
Edit: Never mind, i read a little more carefully. So it should be in stunt 3D mode, and set at mid - 0 pitch
CodeB4U is offline        Reply With Quote
Old 04-06-2008, 05:27 AM   #3
wibble
I ask myself that same question every time I set the head. That "switch" is soooo scary
wibble is offline        Reply With Quote
Old 04-06-2008, 11:22 PM   #4
merlin703
This is really good. What about the tail? I tried downloading the pictures to enlarge it and make it more visible but didn't work
JR X9303 TREX 500, TREX450, Joker 3 (almost ready),Typhoon3D, EZ* FPV, Stryker (Acromaster and EZG still in box)
merlin703 is offline        Reply With Quote
Old 04-07-2008, 08:21 AM   #5
DierWolf
Tail setup is trial and error, keep radio trim centered and move the servo up and down the boom until it holds, tighten down the servo there.
Naturally if your using stock rate Gyro as your battery runs down you will lose hold on the tail, so when setting the tail try to do it with fresh batteries.
I have found the servo should be about 5-6mm from touching the boom block, put it there as a starting point.
Esky Esmart 600
EXI-450 with Scorpion Motor
Esky Belt CP with Direct to Swash Mod & Trex V2 Head/tail
Esky Belt CP with DTS Mod and full esky cnc head/tail
Esky Belt CP w/Airwolf Fuse (Sold) / Esky Lama V4 Full modifications.
Art-Tech Wasp V3 Heli & Art-Tech P-51D w/brushless motor.
DierWolf is offline        Reply With Quote
Old 04-13-2008, 04:29 PM   #6
TD1
I need some help setting up my Belt cp on my JR 3810, I am using the receiver that comes with the heli, and just replaced the freequency.
But the ailerons and elevator seam to be crossed, I have swoped them around but I still get the same effect, and my radio is mode 1.
TD1 is offline        Reply With Quote
Old 04-24-2008, 09:50 PM   #7
Hix
Go into the system menu and make sure the swash program is 3S 120deg....
Hix is offline        Reply With Quote
Old 05-22-2008, 09:01 PM   #8
helibubba
Default not enough pitch range?
Hey guys. I'm pretty new at this and trying to figure out if my Belt CP is set up right. It seems sluggish (requires a lot of control input) and drops when I do give it input. I noticed that it flies better just as the battery is running out and I have the throttle on max to hover. Also, it seems to do better when I turn the dial on the left of the controller all the way up.
I have it basically set up as shown on the first post, except for the adjustable Bell Mixer Pushrod link. I do have it at zero pitch at mid-stick.
I am noticing that it doesn't have as much pitch range as seems to be indicated in some threads and videos. My understanding is that it should max at +10 or +11 degrees. In idle-up mode the range is -7 to +8 degrees. In normal mode it's -2 to +6 degrees. Is this a problem? If so, how can I increase the pitch range?
I've heard it said that if I created two adjustable Bell Mixer Pushrod links and increased the length of them both equally, this would increase the pitch range. My understanding it that this is how it works on the Honey Bee King II. Is this correct and if so, where can I get the parts to make these linkages? Right now I have the EK10548 Servo Linkage Rod set and all of the rods are too long. Could I use the adjustable Bell Mixer Pushrod links from the Honeybee (EK1-0290 Push link set)?
Any help will be appreciated.
helibubba is offline        Reply With Quote
Old 06-19-2008, 12:02 AM   #9
rcaddik
Question swashplate height
hi to all pilots here
i have a question, i think thats everyones in mind. can i asked what is the default height between the swash plate and correct me if im wrong main frame of the belt cp? i dont know how you call it, sorry but im hopping for a good reply thanks to all more power.
rcaddik is offline        Reply With Quote
Old 06-19-2008, 09:53 AM   #10
DierWolf
Height is determined automatically.
Please goto the finless vids in the main forum and watch his CCMP setup video.
In short, you need to set up your Heli in 3d Mode with throttle stick at 50%. at that point the Swashout arms are supposed to be flat and even with eachother, and when that is correct your swash will be at the correct height.
So in other words, your links to the swash will be adjusted to a length that brings the washout arms flat and level with eachother in Idle up mode (3d mode) while throttle stick is at midstick.
hope that explains it.
Look at the First picture in this thread, the Part just above the swashplate is the Washout Arms, notice how they are flat? thats what you need to get and then your swash will be correct height.
Esky Esmart 600
Copyright © 2004-2009 - William James - Helifreak.com
