Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters > Hirobo Electric Helicopters
Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters
Old 04-04-2008, 10:56 AM   #1
docjoe
Default MAH 425mm CF Blades - new outlook
I just wanted to go on record stating that I had a previous bad experience with a pair of 425mm MAH blades for my Lepton/TRex500. These must have been an old pair of blades. After discussing with Jeff at MRC, I sent my old pair of blades back and they sent me a new set. The new set is 59g per blade (1g less than my SAB blades). These blades did not exhibit the same rotor disk loading and bogging during hard 3D (which I had at one time attributed to the Lepton and then the blades). These blades are great. Tracked online immediately, felt stiff and responsive. The cyclic may have been a little slow. I still need to put it through its paces but definitely a different blade than the 2 pairs I had previously.
Joe
"Chancho, when you are a man, sometimes you wear stretchy pants in your room."
-Nacho Libre
docjoe is offline        Reply With Quote
