Old 04-09-2008, 03:07 PM   #1
luky
Default CC HV-85 vs CC Phoenix 80
Is there a good reason to go with the more expensive HV-85 ESC over the standard Phoenix 80amp ESC? It will be replacing a stock Align 75amp ESC with the standard 6s set up (external Align BEC w/battery). No 3D, still just hovering and getting good with FF on the SIM.
I don't foresee going to higher than a 6s set up (but I have been looking into 7s2p A123 packs, which is the equivelent of a 6s Lipo).
Thanks!
luky is offline        Reply With Quote
Old 04-09-2008, 08:01 PM   #2
Dynamic
The only reason to go with an 85HV instead of the phoenix 80 would be to future proof it. and by this I mean in the future if you wanted to add cells.
-=<Codename: Kratos>=-: Logo 600 3D V-bar 1910/1/Y 4270 Evo Lite V-blade mains and tails
Mikado: Lighter Stronger Faster
Dynamic is offline        Reply With Quote
Old 04-10-2008, 11:22 AM   #3
turbine50
Also, with the PHX80, you will be maxing it out, voltage and amperage wise. The HV85 has twice the voltage capacity, bigger capacitors and a heat sink. It wont break a sweat.
turbine50 is offline        Reply With Quote
Old 04-10-2008, 05:11 PM   #4
OverTemp
The HV is a MONSTOR compared to the 80. I went down the same road. Get the HV.
1 - Diabolo 1 stuffed with, well, see below
2 - Diabolo 2 stuffed with testosterone, jittery sweat, and rippling flanks
OverTemp is offline        Reply With Quote
Old 04-10-2008, 11:58 PM   #5
dieselracer
We are running the CC80 just fine. You really dont need it. unless you plan on going higher then 6 cell.
dieselracer is offline        Reply With Quote
Old 04-11-2008, 01:03 AM   #6
Mercuriell
The CC 80 is absoutely fine for 6S and probably has less issues than the HV85
John
Mercuriell is offline        Reply With Quote
Old 04-11-2008, 11:02 PM   #7
aucmax
Issues? What issues? Just curious.
Not one of us is as smart or knowledgeable as all of us bonding together.
Brett
aucmax is offline        Reply With Quote
Old 04-29-2008, 12:50 PM   #8
chimaera
Any reason not to go with a 110 HV just in case?
chimaera is offline        Reply With Quote
Old 04-29-2008, 01:08 PM   #9
wren1702
The HV -110 is a monster compared to the HV-85! BIG!
Alan Haney
T-Rex 600E in 500E Hughes
Swift 16 Flybarless in Approach Cobra
Outrage 550..........Outrage G5........Phazor 600
In memory of: James Archer
wren1702 is offline        Reply With Quote
Old 04-29-2008, 01:29 PM   #10
chimaera
I'm assuming that means it is way overboard.
