Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
View Poll Results: Are your Tx sticks tight or loose? Rating 1 = soft/easy 10 = stiff/hard
1 - Soft 2 14.29%
2 - 1 7.14%
3 - 3 21.43%
4 - 0 0%
5 - 2 14.29%
6 - 2 14.29%
7 - 1 7.14%
8 - 0 0%
9 - 3 21.43%
10 - Stiff 0 0%
Voters: 14. You may not vote on this poll
Old 04-09-2008, 07:03 PM   #1
HeliMix
Default Are your sticks tight or loose?
I am curious as to how others have the the tension on the sticks of your Tx's set. Do you have your stick set so it takes more energy to move it? Or do you have your Tx set with a feather stick? Or do you have it set some where in between?
Any comments as to why you adjust your Tx the way you do are welcomed.
EDIT: I meant to post this in the Blade 400 sub-forum since I fly a Blade. It probably does not really matter, but I was planning on comparing apples to apples.
CX2 | Blade 400 | Trex 500 | RC10 GT2 | Phoenix Flight Sim | MyTube
Mix Design Group (MDG) - www.MixDesignGroup.com
HeliMix is offline        Reply With Quote
