Go Back   HeliFreak > R/C Helicopter Support > Turbine Helicopters
Turbine Helicopters Turbine R/C Helicopters
Old 04-09-2008, 10:22 PM   #1
dacostad
Default First turbine and JR XP9303
Hi all, I am collecting my first turbine powered helicopter on Friday (an Airstar Jetcopter SX) and will be using a JR XP9303 with an XPS module.
Can anyone advise me on correct setup with this radio and in particular how you setup the AUX switch (channel, which switch etc).
Thanks for any help.
David
dacostad is offline        Reply With Quote
Old 04-09-2008, 10:56 PM   #2
cbergen
Without knowing what exactly you want to do with the aux channel, I'm probably not much help, but surely Joseph will be familiar enough with it when you pick it up.
Or are you getting it used?
Either way, Airstar may be your best bet for help.
Chris D. Bergen
Bergen R/C Helicopters
cbergen is offline        Reply With Quote
Old 04-10-2008, 02:25 PM   #3
sgil123
Contact Peter Wales he is on Helifreak. He is a turbine and large scale expert
Steve
Fly hard parts are available
Difficulties mastered are opportunities won!
sgil123 is offline        Reply With Quote
Old 04-10-2008, 06:45 PM   #4
rkeith2
What part of California are you hailing from -
I can share the JetCat settings I have in my 9303 with the aux running the start, idle, spool up and down
Ron Keith
Keith Ranch Santo, TX
AMA CD # 8305, Turbine Waiver 505, IRCHA 2367
Bergen R/C Helicopters -
rkeith2 is offline        Reply With Quote
Old 04-12-2008, 03:13 AM   #5
wirlybird
He is a HELLIFREAK , like most of us.
wirlybird is offline        Reply With Quote
Old 04-12-2008, 11:20 AM   #6
dacostad
Hi Keith, I live in LA.
I picked up my JetCopter yesterday and I ended up putting a 10 channel XPS receiver on it so that I could use the right pitch lever for start, idle, spool up and down. Without this I could only use channel 7 for the left Aux 3 lever which meant I could not use the gyro functions on the radio.
Anyway it all fires up nicely.
I still need to set the failsafe on the XPS and at first I could not figure out how to do it as we don't use the throttle channel, but I assume I set channel 8 up as a user definable channel on the XPS receiver and then set the failsafe position to the turbine off position of the right pitch lever.
David
