| Electric Micro/Mini Helicopters Electric Micro Helicopters Discussion |
Hi, I need help to enter the Advance menu on a Quark 33 ESC, I do follow the instrucctions I downloaded from the site but, I'm unable to get to the 'Advance menu' so I can change the 'cut-off voltage' setting, if any one has this ESC and can help me out, thanks
Hey,
I fly for Quark and so can help you in your dilema. In the older V1 Quarks you could only access the Advanced menu if you first selected Car or AIR as the model type in the first menu selection. Then go through all the other options in Basic mode, then go into Advanced mode and set motor type etc. etc. Once this was done, re-enter the basic setup mode again and choose the aircraft type you want to fly which is most probably going to be Heli 1,2 or 3 and then disconnect the battery to stop the programming sequence. Once reconnected and initialised you are ready to fly with all parameters set the way you want them to be. Later V2 Quarks allow you to set any model type you want and still be able to setup the Advanced options, V1's require the above trick. Here are some seperate instructions I wrote for when we sold the Quarks with the 3d PRO's here in the UK, these may give you some extra help : http://www.coolice.co.uk/Quark-Manua...anContessa.doc Any other problems or questions just ask. .
Ian Contessa Team Robbe SchluterUK / Midland Helicopters / Align To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
