Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 04-24-2008, 03:49 PM   #1
Rickard
Default Throttle servo on spectra destroyed X 2
I have had a throttle servo, JR std that the gearbox broke .
So i switched to a JR digital servo, and the mounting ears broke on one side after 5 flights.
What is causing my servos to fail?
I use a CSM govenor, can it override the max and min settings i have in my radio?
Rickard is offline        Reply With Quote
Old 04-25-2008, 09:38 AM   #2
rbort
Default Sounds like
You have something out of alignment. I'd check the motor to clutch alignment by taking the spark plug out and pulling the motor through and watching the muffler/air cleaner to see if there is any wobble coming from turning the motor around. Its possible to have an out of round delrin ball on the clutch that can cause this and make for excess vibrations.
Other things to check is the balance of the motor if its not already balanced (rotor at least).
-=>Raja.
1005 Xcell Autorotation Queen, Hanson G26 3D Max, 3333 flights
Spectra-g, Hanson 270 3D Max, 2200 flights
Whiplash-g 88.9mph Speed Cup Record, Hanson 270 3D Max, 280 flights
Jewel on-board Generators, Team Miniature Aircraft, Team Helicommand
rbort is online now        Reply With Quote
