Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 04-27-2004, 10:29 PM   #1
macro heli flyer
Default center of gravity question??
should the cg for the heli be exactly in the center rotor shaft, or should it be a little nose heavy.. I read something on that somewhere but cant remeber where... also I have a 2700mh 4cell bat to charge , I have a mrc supper brain charger but the bat says slow charge for 13 hours at 270ma . does that mean .27of an amp? and fast charge at 1350ma my charger onl;y goes to 4.5 amps....
Over here the moskitos are as big as my macro 50 heli...
macro 50
os 50
401w-9253
max66 w jr 539's
jr battery and 555 rotors
macro heli flyer is offline        Reply With Quote
Old 04-28-2004, 06:02 AM   #2
ImRich
I believe you want the C/G under the rotor shaft. If someone else thinks differently, I'll learn something too!
As to the charging rates...
First: 1000mA is 1 Ampere. Or put another way, 1 mA is 1/1000 of an Ampere
To charge at 270 mA is correct at .27 of one Amp
Fast charge of 1350 mA would be to charge at 1.35 Amps
If your charger goes to 4.5 Amps, then it goes to 4500 mA
Your probably have a 4 cell 2700 mAH battery. This means that the battery should be able to supply 2700 mA for an Hour (this is what mAH means, it's MilliAmpere's per Hour). Of course, it should be able to supply more current for less time, or less current for more time. For example, if you had a 5.4 Amp load (or 5400 mA) the battery should be able to last for 30 minutes. You are drawing twice the rated capacity of the battery, so it should last about half the amount of time. It's not a perfectly linear scale, but this should give you the idea.
Does this help at all?
Rich
X-Cell Gas G231PUH (for sale), Raptor 50V2 OS50, Blade CX
ImRich is offline        Reply With Quote
Old 04-28-2004, 07:37 AM   #3
Doug
You "can" fly with vertually any CG, but when you start flying inverted you will find that "centered" is best
"If it ain't broke ,fix it till it is"
Doug is offline        Reply With Quote
Old 04-28-2004, 12:48 PM   #4
macro heli flyer
thanks Rich for your imput it really appreciated.. thank god there is sites like this, or eles i would be in big big trouble,, rob.... :glasses2:
macro 50
os 50
401w-9253
max66 w jr 539's
