Old 05-19-2008, 01:15 PM   #1
wren1702
Default My Advice for anyone building a new 600E....
Just my 2 cents worth. Go ahead and sell the 600Xl motor and stock ESC and go 8S! Pick yourself up an HV-85 or anything else that'll handle 8S and a 1910/1Y/H motor. You'll enjoy your Helicopter 10 times more with longer flight times, more power and increased longevity of components. We've had real good results with the 8S 4270 EvoLite batteries from FlightPower.
Just looking at the number of threads about power questions and issues made me create this little thread.
Have a great day!
Alan Haney
T-Rex 600E in 500E Hughes
Swift 16 Flybarless in Approach Cobra
Outrage 550..........Outrage G5........Phazor 600
In memory of: James Archer
wren1702 is offline        Reply With Quote
Old 05-19-2008, 01:27 PM   #2
eightythree
ahh its to bad i spent my moneys on the stock setup.. oh well, if i had known 6 months ago when i got the kit i would have!
listen to wren! you shall not be disappointed.. and oh, check the scratch and dent over at grand rc.. i think i saw a GF kit for like 400 bones!
eightythree is online now        Reply With Quote
Old 05-19-2008, 01:30 PM   #3
wren1702
Which is exactly why I posted this! AFTER you've bought several batteries is not a good time to change setups! An 8S FlightPower battery is only $29 more than a 6S.
Alan Haney
Old 05-19-2008, 01:31 PM   #4
eightythree
just to add.. i know 8s is ideal for this size electric, but someone has to produce a decent more effecient motor to run on 6s. i dont think the power is all that bad with the XL on 10 tooth, well if you arent doing crazy fast 3D moves...
Old 05-19-2008, 01:32 PM   #5
eightythree
or keep your stock setup 600, and build another with 8s!! i may just max out my credit card.. lol
Old 05-19-2008, 02:10 PM   #6
blueviewlaguna
Have a great day!
Hi Alan - what is the highest battery temp you have recorded with this setup?, I seem to recall 133F for the 8S 4270 with another 600 sized heli (Gohbee Phazor 600e?) you are running with the same power system (and that heli was about the same weight as a stock frame T-rex 600).
600CF 10S - GY611/BLS251, 8717's, X-ERA 4025, JIVE 80HV, TT, Kasama Tail, Radix, Custom Heli frame
600CF 6S - GY611/BLS251, 8717's, X-ERA 4020, JIVE 100LV, TT, Kasama Tail, Radix, 2mm Frame
500ESP 6S - GY520/BLS257, BLS153's, Neu 1706 1.5, JIVE 80LV, TT, Kasama Tail, Radix
blueviewlaguna is offline        Reply With Quote
Old 05-19-2008, 02:30 PM   #7
wren1702
About the same Temp, 133 to 140.
Alan Haney
Old 05-20-2008, 08:28 AM   #8
RobertAbles
I second Wren's motion!
The 1907, 8s setup is perfect on the T600. Your talking 3000 watts (yes that is 4 hp) of power and it doesn't stress the packs like the 1515 6s setup does.
It does not bog at all and overall it is cheaper as well.
CC85 170.00
1907 165.00
4270 8s 330.00
Total 665.00
6s
1515H 275.00
CC85 170.00
4900 6s 299.00
Total 744.00 NO BRAINER!!!!!!!!!!!!!!!!
Seriously, it does work VERY well......
Robert Ables
GAUI USA Team Pilot / Spinblades
Scorpion Power Systems / MKS USA / Gens Ace / Rotor Rage / YS Engines
RobertAbles is offline        Reply With Quote
Old 05-20-2008, 08:38 AM   #9
wren1702
CC85 170.00
1907 165.00
4270 8s 330.00
Total 665.00
6s
1515H 275.00
CC85 170.00
4900 6s 299.00
Silly Me....I keep forgetting about the 1907...and I own one of them!
Alan Haney
Old 05-20-2008, 04:05 PM   #10
RobertAbles
Wren in the Phazor, you are able to get the 1910 geared correctly, as where with the T600 the 1907 1400kv just gets the gearing targeted perfectly for the castle gov. mode.
I think this is why Clint likes it so much... PLUS it's freakin cheap!
Robert Ables
Old 05-20-2008, 04:19 PM   #11
wren1702
That's the really great thing about the 1907...Price!
Yep, The Phazor has more gear ratios than you can shake a stick at!
Alan Haney
Old 05-20-2008, 05:59 PM   #12
JesusFreak
Wren:
I'm still trying to build my second 600E with the RW HFE Frame. So a few questions for you.
Will the 8S setup fit in the HFE Frame? (Just saw your You-tube vid so I guess it works)
What pinion are you running on the 1907?
Which 1907 are you using the 1 with the Heli Option?
What charger are you using for the 8S pack?
How long are your flight times?
I was just about ready to pull the trigger on a new AT 6S pack, but now you have me thinking.
I already have the CC85HV, so I just need the motor and battery, assuming I can use my TP Charger.
Thanks,
Lee
“One way to make sure crime doesn't pay would be to let the government run it.” RR
TREX450XL, TREX450SE, TREX600E, TREX 600 HFEX, TREX500, Vibe 50
(Professional grade pretzel maker).
JesusFreak is offline        Reply With Quote
Old 05-20-2008, 08:31 PM   #13
4cyclic
8s is probably a good choice, I'm sure, but I'm quite happy with the 1515 and my new 25c Hyperions 5000. I run them hard and they are no more than 125 deg f, after 4.5 minutes. Whatever works I guess.
4cyclic is offline        Reply With Quote
Old 05-20-2008, 08:43 PM   #14
wren1702
Originally Posted by JesusFreak View Post
Wren:
Thanks,
Lee
We were running the 1910 in the HFE, I'll have to look and see which pinion we were using. It was the heli motor that we used. We use TP 1010 chargers. Flight time were right at 5 minutes.
Alan Haney
Old 05-20-2008, 10:49 PM   #15
JesusFreak
OK, so which 1907 model are you using and what pinion? How does it compare with the 1910 setup in the Youtube vid?
Thanks!
Lee
