| 600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Well I was getting tired of these stickers coming off and haven't decided on paddles to buy yet. So, spread a little bit of CA around the parameter of the sticker and pressed on to the paddles. Problem solved! Thought this may help somebody.
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
I did the same thing the weekend before last. At least it kept me flying. The problem is that fuel gets under the stickers, a problem that doesn't exist with the 600e for which the paddled were originally designed.
I bought a Monokote trim sheet and plan to make some better coverings.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
just buy the carbon paddles, that what I did because I ran out of stickers lol
Gravity can really hurt the wallet To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
The align carbon paddles are great, they make it a little quicker on cyclic and are very smooth. On top of that they look good.
700N - Microbeast MSH Protos - Microbeast To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I want to make my paddles match my tail blades and new canopy: all neon orange. It would be a shame (and a waste) to cover up those nice carbons.
#6 |
I never even used mine as I figured the sticker wouldn't last so long on there...
I started with the Align carbons, they work well. If you want faster cyclic the Super Stubz are the way to go.
Bill - RWMAA #1009, AMA #805853 |
#7 |
Hi all,
Just coming back to the hobby after 16 years away. I'm just about to embark on building one of these, question is do you actually need to cover the paddles? if you don't what happens? |
#8 |
They won't be very effective as most of the air will flow THROUGH them..
#9 |
Not sure about that. I have seen a picture of MA's new 450 and it has flow though paddles. I'll try to find that photo and link it.
TREX 700N Flybarless custom direct to swash servos ebay-12projectsnow12 |
#10 |
I wash my paddles to get rid of the mold release. warm soapy water works well
then i use an exacto to place the sticker on the paddle. 60 + flights no issues Martin |
#11 |
Second that. Put them on right and they should last a long time.
AMA# 902812 More stuff than there is time to fly it. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#12 |
I suppose a guy could cover the paddles with a little sheet of monokote - the stuff used on airplane wings. It wouldn't really be worth it, unless you had some already on hand, at $10 or more per roll, but you could match any color you wanted. Just a thought. I'd rather have cf paddles, myself, and do.
-Nathan- Align 600N Super Pro |
#13 | |
#14 |
I don't believe in spending money on upgrades unless you really like the bling. Unless you are down on the deck stock should work just fine.
They make heat shrink that is large enough to go over the paddles. A little heat and the problem is fixed forever. I covered a buddies in yellow and he likes them being that color. I have a set of the Align Carbons on mine but I covered the stock paddles for backup just in case. I got the heat shrink from Batteries America. It is for shrink rapping large battery packs... I hope this helps!
Charles To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#15 | |
Why didn't I think of that? I think Fry's may even carry some that large, although getting it in neon orange -- or any shade of orange for that matter -- may not be easy. Did he use any sort of adhesive to make sure it doesn't slide off as a result of centripetal force?I already bought the Monokote, so I'll try that first.
#16 |
well i used yellow shrink wrap but i cut the edges so it looked good.. and BANG!! it flew off in flight..
so if you all wanted to know if it can fly without the stuckers... yes! it can
˙˙˙pǝʇɹǝʌuı ʎlɟ ı |
#17 |
Hi,
I have tested the Align carbon paddles and I think the cyclic speed of the helicopter is too slow for me. So I have added a transparent heat shrink sleeve. This works perfect and looks great. All the best, Klaus |
#18 |
anyone tried to fly naked align pad without sticker on???? i will give it a try today
#19 | |
RC Helicopter product reviews and general musings: The HeliGeek's Blog To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
