Belt CP E-Sky Belt CP
Old 05-23-2008, 01:48 AM   #1
1972neo
Default head speed drop suddenly
hi! i have problem for belt cp thro curve setting,using futaba 6ex 2.4g, my setting for pitch curve (-2,-1,0,5,10 normal mode).(-10,-5,0,5,10 idle up).thro curve (0,20,40,60,80 normal mode).(100,70,50,70,100 idle up).just start hover my heli less than 1minute & i feel my heli suddenly powerdrop(about 20%-30%drop).first suspect my battery(3s1p 11.1v 2200mAH)problem,but the original come with beltcp battery(11.1v 1800mAH)also same problem !!!. SOMEONE CAN HELP ME !!! THANK'S
1972neo is offline        Reply With Quote
Old 05-23-2008, 01:58 AM   #2
sortegon
I think your ESC is overheating and shutting down... try getting an external BEC to power up your receiver and servos and that should fix your problem.
Trex600NSP| OS50Hyper/MP5 | JR 770 w/8900 & JR8317x3 & JR8231x1 | Youngblood main/tail blades | Align gov |
Trex450SE | Scorpion 2221-8 / ESC60A v2 | Hitec 65MGx3 @ 6v | Hitec gyro 5000/5083mg | Youngblood main blades | Gorilla Paddles |
sortegon is offline        Reply With Quote
Old 05-23-2008, 04:34 AM   #3
helihathnofury
Hi, hope you don't mind me saying, but you are running a low rpm and requiring a lot of pitch to lift [in NORM]. In other words, you are creating a load of blade drag, and the copter will handle very sloppily, having very little spare blade angle to play with. Better to have high rpm and low pitch angle of blades - more stable. I am no ace in this and will gladly swallow a large portion of humble pie, but I have spent around a week or two playing with these settings, taking advice from the true ACES on this forum, and the high rpm throttle settings is def the way to go
Mike
Ps my settings in NORM are
Throttle 0,35,70,85,100
Pitch 45,50,55,75,100
= I lift at about 77%rpm and only 1 degree of pitch!!
Happy Heli-days !!!!!!!! Skip
T-Rex 450Sport, T-Rex 500ESP,
T-Rex 600NSP FBL, OS55, MicroBeastX Plus,
Futaba 14SG,
helihathnofury is offline        Reply With Quote
Old 05-23-2008, 04:05 PM   #4
DierWolf
low rpm with high pitch is VERY inefficient, its best to run a higher headspeed with lower pitch.
Also this draws alot of amps from the battery that way and causes the ESC to overheat... Putting on a BEC will not solve overheating problems.... recheck your pitch settings and that everything is running smoothly on the heli itself (also belt tightness and gear mesh) All those contribute to high amp draw causing overheating of the ESC.
Esky Esmart 600
EXI-450 with Scorpion Motor
Esky Belt CP with Direct to Swash Mod & Trex V2 Head/tail
Esky Belt CP with DTS Mod and full esky cnc head/tail
Esky Belt CP w/Airwolf Fuse (Sold) / Esky Lama V4 Full modifications.
Art-Tech Wasp V3 Heli & Art-Tech P-51D w/brushless motor.
DierWolf is offline        Reply With Quote
Old 05-23-2008, 04:21 PM   #5
Ian 777
Did you devise those curves or did someone else reccomend them?
I agree with Wolfie and Mike, and a BEC will help with efficiency too.
Also do you lubricate your heli?
Ian
Trex 500 ESP
Phoenix Flasher 450
Frankenbelt
Ian 777 is offline        Reply With Quote
Old 05-24-2008, 07:17 AM   #6
1972neo
Hi ! lan ,no one reccommend ! because i thougth more high rpm get more battery power draw.so i set like that ! i see all your reply . now i know my thinking is wrong ! so now my first thing is to reset my thro curve to get more high rpm THANKS FOR YOUR HELP !!! SORTEGON,MIKE,WOLFIE,LAN !!! THANK YOU VERY MUCH
Old 05-24-2008, 07:33 AM   #7
Ian 777
You are very welcome
We all know how many difficulties arise when your starting out
Trex 500 ESP
Phoenix Flasher 450
Frankenbelt
Old 05-24-2008, 11:01 PM   #8
sortegon
Your welcome!!
Even if you fly with low RPM, your ESC should hold... but for some reason it doesn´t. Check everything is lubricated and not too tight.
Powering up your receiver and servos produces heat in your ESC, so if you use an external BEC to take care of them, your ESC will work better and cooler, only providing juice to the motor and should hold even if you fly with low RPM.
