Old 05-24-2008, 12:08 PM   #1
RADTECH
Default 7c pcm glitch
hey guys i have a 7c pcm and a 450v2
I have intemittent glitches I loss power for a second and it starts back up luckily it never resulted in a crash but is very annoying because I also have this in my head which prevents me from flying relaxed. Is there anything I can do to correct this?
RADTECH is offline        Reply With Quote
Old 05-24-2008, 12:27 PM   #2
forjer
Re-route your antenna? I'm using a 7C in PPM and I had the same intermittent power cuts. I actually went with a base-loaded whip antenna and haven't had the problem since.
It's amazing what you can do when you don't know that you can't do it. ~unknown
forjer is offline        Reply With Quote
Old 05-24-2008, 12:30 PM   #3
RADTECH
Im actually using the deans base antenna what's wierd is I have no poblems in my trex 500 only the 450
