Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 05-25-2008, 09:50 AM   #1
Finless
Team Taco VP
Default Trex700 Manuals
Below are 2 versions of the manual. The Production manual and the Pre-Production manual.
Thanks to Victor for supplying the Production version of the manual.
Align Trex700 PRODUCTION manual PDF format (25 Megs)
Align Trex700 PRE PRODUCTION manual zipped JPG format (13 Megs)
Bob
"Don't Taco My Pack Dude!"
Old 05-25-2008, 10:35 AM   #2
george0079
File does not exist please contact the systems administrator
The link isn't working............
If, at first, you don't succeed, then skydiving is probably a bad idea for you.
george0079 is offline        Reply With Quote
Old 05-25-2008, 10:38 AM   #3
Finless
Team Taco VP
Ooops.... typo in URL.... Fixed.
Bob
Old 05-25-2008, 10:42 AM   #4
george0079
SWEET....
Thanks again Bob... You Da Man
Old 05-25-2008, 10:51 AM   #5
george0079
Wow. That kinda sucks. That build looks easy and fast. I was hoping it was gonna take a little longer.
Old 05-25-2008, 10:54 AM   #6
Helirob
Kegerator Shill Account
Thanks Bob, you are the greatest.
Rob
Helirob is offline        Reply With Quote
Old 05-25-2008, 12:27 PM   #7
Megahertz
Here's a pdf version.
http://www.3dtechdev.com/helifreak/t...700man_pre.pdf
Megahertz is offline        Reply With Quote
Old 05-25-2008, 12:30 PM   #8
Finless
Team Taco VP
COOL thanks Megahertz..... I removed the JPG version and am uploading the PDF version now. Give it 5 minutes and it should be up.
Thanks man.....
Bob
Old 05-25-2008, 07:30 PM   #9
jet22b
Many thanks to Bob and Megahertz for the 700N manual!!!!
I know things may change when the final manual come out, but, this will give me a good headup on the build of this bird!!!
Thanks again, guys!!
jet22b
My your blades hit smooth air!!
T-Rex 600N Pro-OS Max50-Futaba GY611/S9256-DX-7 System
5 T-Rex 600E in Hangar!!!!!
AMA Member
T-Rex 700N PRO - OS MAX 91SZ
jet22b is offline        Reply With Quote
Old 05-26-2008, 04:48 AM   #10
heliguychris
Originally Posted by Finless View Post
OK per request here is the PRE RELEASE manual.
EXPECT CHANGES!
THis is just scans of the pages in JPG format. If someone wants to make this a PDF please do and I will replace it.
Align Trex700 manual zipped JPG format (13 Megs)
Bob
Your a legend, cheers for that
heliguychris is offline        Reply With Quote
Old 06-24-2008, 05:47 PM   #11
Rockohaulic
Torque Tube
The manual has the 2 bearings on the torque tube evenly spaced from each other, and evenly spaced from the ends.
What gives?
This is in complete contradiction to the 600 where the bearing is offset to help reduce vibration. If the bearings are evenly spaced, they act like nodes and set up a harmonic vibration.
Any idea why they went away from this when they got it right the first time?
Rockohaulic is offline        Reply With Quote
Old 06-27-2008, 06:57 AM   #12
harryboe
The situation with 2 bearings is a bit different. To crate a harmony wave the length of the middle section has to be twice the length (or multiplied by two) of the outer sections.
That's obviously not the case for critical lower frequencies and not an issue on higher ones. But it does not hurt to have it just a few millimeters offset ..
harryboe is offline        Reply With Quote
Old 12-31-2008, 09:21 AM   #13
Finless
Team Taco VP
The manual can now be downloaded directly from Helifreak. I added a link to the first post so it is listed with the Pre-production version as well. It is also below for quick access.
Bob
Old 01-12-2009, 09:34 AM   #14
ryblack04
Default OS91HZ manuel
Does anyone know of an online manual for the trex 700 engine... I didnt get one and need some pointers on what the short needle valve is for and for tuning info.
thanks
Blessed is the man who perseveres under trial, because when he has stood the test, he will receive the crown of life that God has promised to those who love him. James 1:12
ryblack04 is offline        Reply With Quote
Old 01-12-2009, 12:17 PM   #15
OTA
thanks
Made a reply to you in this thread http://www.helifreak.com/showthread.php?t=113299
Someone should move it to "engine and muffler" forum.
T-Rex 650 CF / Scorpion 4025-630, 12S
Jive 80+HV,2 x TP 3300 6S V2, Radix 710SB,Super Stubz,Futaba 9451,Spartan DS760/BLS251.Quick UK swash and tail
T-Rex 700N, OS 91HZ, Hatori 939, Radix 710SB, BLS 451, 9254 for throttle, Spartan DS760/BLS251, Quick UK tail,
OTA is offline        Reply With Quote
Old 01-30-2009, 05:37 PM   #16
THX1138
Thanks!
Lou
Time is an illusion. Lunch time, doubley so.
THX1138 is offline        Reply With Quote
Old 03-05-2011, 06:18 PM   #17
dizzymarkus
does or has anyone a manual with actual part numbers on them other than Chinese I dont read ?
Thanks a ton,
Markus
dizzymarkus is offline        Reply With Quote
Old 03-10-2011, 08:01 PM   #18
Helico-pteron
700LE
700LE 3G
700E
700E FC3 Super Combo
700E 3G Super Combo
Lynx Team Pilot
Grand
RC Field Rep
BEASTX
Helico-pteron is offline        Reply With Quote
Old 03-10-2011, 09:12 PM   #19
dizzymarkus
Ty but the individual part numbers are still in chinese or something I can not read. AQll the previous manuals have had the actual part number along side it --usually aghn#### or something like, that please see pic ;0)
thank you,
Markus
Old 03-31-2011, 02:09 PM   #20
ualdrivr
Originally Posted by Helico-pteron View Post
At the precipice, we change!
Team GrandRC
ualdrivr is online now        Reply With Quote
