Old 05-31-2008, 02:43 PM   #1
khaled_abobakr
Default What is throttle hold ???!!
I wonder what throttle hold is ... and is it useful to use it when take off or land ??
Thank you very much
Khaled
khaled_abobakr is offline        Reply With Quote
Old 05-31-2008, 02:45 PM   #2
DominicD
The Capi - HF Support
Throttle hold turns the motor off on an electric heli. This is useful for doing autos but more importantly you MUST hit TH before you crash or the damage will be very extensive.
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is offline        Reply With Quote
Old 05-31-2008, 02:51 PM   #3
alienteabagger
Throttle hold (also known as the "OH SH!T SWITCH" or the OSS) kills any and all power to the drive train. Like HFG stated it is used to perform off power manuevers like autorotations. Many use it to prevent excessive damage in the event of an unplanned collision with the ground or other inmovable object. With the right timing, proper application of the OSS can greatly reduce the damage from very ugly crashes.
Zit: T-Rex450SA w/ 430L 13t pinion - My flying backscratcher
Tiny: Raptor .50 w/TT .50 engine - One bad machine!
One DX6i to rule them all!!
Have a gyro/tail/wag problem? Check here
alienteabagger is offline        Reply With Quote
Old 05-31-2008, 02:56 PM   #4
DominicD
you MUST learn to fly with a spare finger on the TH button, you wont be able to find it in time during a crash.
Team KBDD
Old 05-31-2008, 03:02 PM   #5
khaled_abobakr
then what is the difference between throttle hold and throttle cut .. actually on my Futaba T6EX 2.4ghz I have a flip switch on the upper right side which is the throttle hold switch and another push button beside the screen which is the throttle cut ....
now I am confused ??!!
Old 05-31-2008, 03:05 PM   #6
DominicD
ON an electric there is no difference. On a nitro throttle hold puts the engine setting low enough that it disables the clutch but keeps the engine at idle so you can re-engage it quickly. Throttle cut kills the engine and you can't restart it.
Team KBDD
Old 05-31-2008, 03:09 PM   #7
khaled_abobakr
Thank you very much HFG
Old 05-31-2008, 06:42 PM   #8
Soarmax
Throttle Hold is you friend. I use it to take off and I use it to land.
Helicopters don't fly -- they beat the air into submission.
If something hasn't broken on your helicopter -- it's about to.
T-Rex SA - Full Metal - 430L/35G/12T - 65MG/401/3154 - DX7/6100
T-Rex V2 - 430XL/35X/12T - 65MG/401/3400G - DX7/6100 -- T-Rex 500CF - 5245/GY520/9257 - DX7/6200
Soarmax is offline        Reply With Quote
Old 05-31-2008, 06:49 PM   #9
DominicD
How on earth are you using TH on take off ??
Team KBDD
Old 05-31-2008, 07:12 PM   #10
Almazick
As a matter of fact using Throttle hold on take off will safe a lot of damage and minimum wear on the heli
Almazick is offline        Reply With Quote
Old 05-31-2008, 07:15 PM   #11
billbill242000
I'm confused also...how does TH work for a take off??
billbill242000 is offline        Reply With Quote
Old 05-31-2008, 07:17 PM   #12
DominicD
LMAO. Yeah this should also help prevent the lipos from puffing.
Team KBDD
Old 05-31-2008, 07:41 PM   #13
rabidguineapig
Maybe so you don't chop your fingers off cause you have idle up on when you plug your battery in...
T-Rex 450SE V2- HS-65MG's, 401+9257, 430XL 11T, evo 25, evolite, Stiffies
GO SABRES!!!!!!!!
rabidguineapig is offline        Reply With Quote
Old 05-31-2008, 08:09 PM   #14
DominicD
That is not taking off.
Team KBDD
Old 06-01-2008, 04:23 AM   #15
Soarmax
Real simple, just put on TH, move throttle stick to mid point, flip to idle-up, flip off TH, wait about five seconds for soft start to bring it up to rpm, and take-off.
Caution: don't do this if you don't use soft start.
For landing, just flip TH about six inches off the ground and it land's itself.
Old 06-01-2008, 04:38 AM   #16
Leftyatm
I'm still a relative newb but that seems like it would cause an unnecessary shock or jolt to the drivetrain that could certainly induce stripped and or missing teeth. Excess wear and tear on a motor and well everything throughout the head. That was the purpose for soft start.
Leftyatm is offline        Reply With Quote
Old 06-01-2008, 04:56 AM   #17
Soarmax
No it doesn't. Soft start begins really slow. Must slower that most beginning flyer do. It puts less strain on the drivetrain that a manual start at regular speed. My ESC settings are: 1 2 2 2 2.
Old 06-01-2008, 11:52 AM   #18
DominicD
Okey thats what the normal but its not TAKING OFF.
Team KBDD
Old 06-01-2008, 05:06 PM   #19
PanicRev
Also keep in mind, most throttle cut buttons only work as long as the button is depressed. If you take your finger off the button before you go to throttle hold you'll be right back into the chicken dance.
Learn to hit that switch. I even do it in the sim. It has to be automatic. If it's not you're gonna be too late.
____________________
TREX 450 SE V2
GY 401, s9650 and hs 65's.
___________________________
PanicRev is offline        Reply With Quote
