... towards front, or towards back? Looking at people's 'rex pictures, I see some pointing front, some pointing back. Which is the "correct" or "proper" way? I'm using a 9650.
AMA #907698 |
I don't think any one way is inherently better than the other. Personally I think the center of gravity (CG) is the determining factor. Point your tail servo in the direction that helps balance your aircrafts CG.
Opinions may differ, this is only mine |
Well, I guess whatever will work for you in achieving the right CG......sometimes moving the tail servo will get the balance point closer for you....but, I never had luck with a 9650....it was always tail heavy with it.....
. . Sport Flying ain't so bad To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. [SIGPIC][/SIGPIC] |
