Old 06-15-2008, 08:36 PM   #1
dxl007
Arrow Head Vibration and TX Setting
Hello,
Had a Blade 400 and decided to move up to a T Rex 600 E CF.
Here is the back ground; I have a 600 E CF with stock electronics a 6S 5000MAH battery, and the 600XL Motor. I put Futaba servos in the collective S9452, and on the rudder I have S9254 with a GY401. The receiver is a spectrum 6200, and a DX6i TX. It has the torque tube up grade, and CF blades. I built it from the ground up using Bobs videos. (Thanks BTW) I have the swash plate perfectly level, and the pitch in dead on at 0 degrees middle stick, and + 11/ - 11 respectively.
As it runs up to speed the head shakes, and does so until it reaches almost middle stick @ 75% throttle. Then the shaking stops till you power her down, and as it slows the head shaking returns. All the parts are brand new and strait as I checked them as they were installed. Any thoughts, or is this normal for the bird? For the record I did try a different set of blades, and got the same result. They are tight, but not too tight. I also tried running her up to speed and leaving the stick at middle and then turning on idle hold so as she powered down, it was at 0 pitch and still the head shook.
Now for the TX settings, I just want to get and idea if these look correct.
GYRO Set at
67.5%
THRO CUR
NORM 0-60-80-90-100
STUNT 100-92.5-85-92.5-100
HOLD 0.00
PITC CUR
NORM 0-45-50-75-100
STUNT 0-25-50-75-100
HOLD Same as above
Swash MIX
AILE -60
ELEV +60
PITCH -70
REVERSE
THRO N AILE R
ELVE R RUDD N
GYRO N PITC N
SWASH TYPE
CCPM 120
She flies great, although you can feel the weight of this thing in the TX. Just hovering her for now as I am trying to get a feel for her (3 Batteries so far)
Anyway I would really appreciate the pros taking a close look over my settings and letting me know if Im on the right track. I would hate to have something miss figured, and she fall out of the sky.
Thanks again
Blade 400
CF Blades, Yellow canapy, Futaba S9650, GY401, 3 HS-65MG, Wing Tote.
T-REX 600 E CF
CF Blades, Max Amps 6S 5000MAH Batt, 3 Futaba S9452, on Rudder Futaba S9254 with a GY401, Torque Tube, Spectrum 6200, and DX6i
dxl007 is offline        Reply With Quote
Old 06-16-2008, 03:52 AM   #2
Mercuriell
YOur settings look OK although there does seem a lot of PITCH AFR - have you checked the pitch with a gauge - some degree of shake is common in the T600 as you describe - check you blades for balance and also blade tightness - they shouldn't move if you hold the heli on its side and give it a gentle shake - I would suspect they are a tad too loose
John
Mercuriell is offline        Reply With Quote
Old 06-16-2008, 01:56 PM   #3
dxl007
Yes I have checked the pitch with a gauge, and it is spot on.
Blade 400
T-REX 600 E CF
Old 06-16-2008, 03:48 PM   #4
Azzurra
Are you using the black or the grey dampeners? It sounds like you are using the black, stiff ones. Try the softer grey ones.
And very simple: Don't take off from concrete! Get softer ground to avoid ground resonances.
Cheers!
T-Rex 600 CF | VBar |TT|Plettenberg 30-12HE|JAZZ55-10-32|3X9252|9254|FF-6, FASST|Radix600|SLS3700ZX 10s packs
Azzurra is offline        Reply With Quote
Old 06-16-2008, 05:11 PM   #5
caldwellj629
Sounds like your just a jack-a$$ to me
caldwellj629 is offline        Reply With Quote
Old 06-16-2008, 05:18 PM   #6
dxl007
Real nice..... Thanks for your insite
Blade 400
T-REX 600 E CF
Old 06-16-2008, 05:21 PM   #7
caldwellj629
Anytime- just let me know if you need anymore advice, LOL
Old 06-16-2008, 05:31 PM   #8
dxl007
Yeah you'll be the first one I call..... Clearly you're the MAN...lol
Blade 400
T-REX 600 E CF
Old 06-16-2008, 05:45 PM   #9
caldwellj629
Yeah- i hear that all the time but it never gets old !!!
Old 06-16-2008, 06:19 PM   #10
Megahertz
Did I miss something?
Megahertz is offline        Reply With Quote
Old 06-16-2008, 09:38 PM   #11
caldwellj629
we are just kidding !!!!
