Old 06-17-2008, 02:11 PM   #1
Finless
Team Taco VP
Thumbs up Review - KDE's 600e Ali Bottom Plate
Here is a little reviewage for ya all.
KDE Direct sent me this aluminum bottom plate for the 600E. Looks pretty good and may save your frames in a crash! We wont be trying to crash so I wont know how well it does in a crash until that day comes.
Anyway, here is the video:
Video Link ->KDE Direct's 600 Aluminum Bottom Plate (15 Megs)
Enjoy,
Bob
"Don't Taco My Pack Dude!"
Old 06-17-2008, 02:34 PM   #2
kitty20155
I believe it helps protect the frames to some extent. It requires scientific methods to find out whether or not and how much it does help. It's NOT 100% safe to jump into any conclusion even with experiences which are not always objective.
kitty20155 is offline        Reply With Quote
Old 06-18-2008, 07:43 AM   #3
Bobbyk
Location: Born in London, Live in ATL, Heritage from Ghana
It looks nice, but it cost $80 bucks, hmm!!!
Robert
<<< Ashlyn, daddy loves you more than his heli's, don't mind mummy >>>
<<< ..............MA Spectra G (Supporting Made in USA), DX7.............. >>>
Bobbyk is offline        Reply With Quote
Old 06-18-2008, 08:20 AM   #4
Mercuriell
Looks really nice - no way will it protect the frames - quite the opposite as it won't absorb impact but it will stop the tedious breaking off of of the nose plate that holds the lipo - don't forget the nylon bolts for the U/C - that's the best protection for frames
John
Mercuriell is offline        Reply With Quote
Old 06-18-2008, 09:19 AM   #5
kegerator
Mercuriell -
According to finite-element analysis, the Aluminum design will acutally minimize the damage to the frame in most crash scenarios, as the aluminum will support the shock and prevent flexing of the carbon frames, which causes the breakage. In the event of a crash, the stock plastic frame flexes tremendously and provides no support to the carbon structure, which quickly causes the epoxy within the carbon matrix to shatter. Carbon-fiber weave is very good in symetric and smooth loading, but is brittle in sudden shock-type impacts, which shatters the epoxy within the carbon lay-up and results in cracks and breakage. Of course, if you put it in hard enough, things could still break and that's why I wanted to offer a 30% off crash-replacement program. On the other hand, in my own experience and multiple hard crashes with the upgrade I've had installed for over a year, I've had no damage to the 600E frames and electronics tucked inside for protection. Also, to prevent breaking the landing gear as well, you can use nylon screws in this design to secure the landing gear, which will shear off in the event of a crash and prevent further damage. The primary goal of the design is frame rigidity and crash protection for the electronics, so using the carbon frames and the aluminum base plate provides excellent protection for the expensive components tucked inside (such as the ESC, gyro computer, BEC, etc.).
TREX 700E - 12S VBAR (KDE 1917H/1Y-N42 S2, CC ICE HV160)
TREX 550E - 6S VBAR (KDE 1907/1Y-N42, CC ICE HV80)
KDE Direct (
Performance Video (
kegerator is offline        Reply With Quote
Old 06-18-2008, 12:31 PM   #6
LITHIUMSTATIC
Lord Rumball
That is sweet!!! If I owned a Rex600 I'd buy one for sure!
LITHIUMSTATIC is offline        Reply With Quote
Old 06-18-2008, 04:35 PM   #7
Mercuriell
Originally Posted by kegerator View Post
Mercuriell -
Don't get me wrong - I'm not knocking the product - I ordered one just after I posted However although I'm not a professional engineer and not capable of finite element analysis I deal with material science every day ! I don't understand your term "support the shock"- a material will either absorb energy or transmit it - can't undestand the concept of 'supporting it' - alumimium being a less flexible material is bound to transmit more of the shock to its surrounds and this is common experience with changing components in the head from plastic to metal - you can have the benefit of increased rigidity and durability but at the expense of more shock transmission. As far as lipo protection is concerned again there is a harder base for the lipo to decelerate against so whilst it might offer more belly protection against sniping air rifles I'm unconvinced it'll do more for your lipos in a crash.
Anyway - I say again - I think it looks a great product and I wish it every success and am looking forward to receiving mine - how about something similar for the battery tray - again to stiffen up the frames as they do tend to flex in this area in front of the main shaft.
John
Old 06-18-2008, 05:50 PM   #8
Finless
Team Taco VP
Well I am no engineer either
But I will add that I have broken the frames around the bottom plate where the notches are and because the screw holes are there DAMN,.... NEW frames for a SIMPLE break! When the bottom plate breaks this breaks the frames around the notches.
I think this will not do that. I don't think it will save breaking the frame up higher which happens depending on how you go in on the crash. But for the simple breaks around the bottom plate notches I think this will keep that from happening. Just my simple thoughts and non-scientific analysis.
Personally, the 500 also needs this big time. My first crash was me messing around with blade stop autos. I came straight down and because the bottom blade broke the tabs around the notches in the frames broke too
Bob
Old 06-18-2008, 09:56 PM   #9
kegerator
Yeah, no problem Mercuriell, I knew you weren't knocking the product. It's great to see an open discussion on the design, as it just helps me design even better products for the future and continuously make improvements. I posted the reply to explain the strength as best I could, without getting too crazy technical in Engineering speak. As Bob stated and I agree, the frame could still break above the frame, as they are unsupported in the area, but I'm confident it should help stop the simple breaks around the frame tabs and lower CF areas. I also broke the 600 and 500 CF frames in these lower areas when I was using the stock plastic bottom bracket; which drove me in developing the Aluminum upgrade bottom brackets for production (and of course, spoil my own self with the upgrades).
KDE Direct (
Performance Video (
Old 06-18-2008, 10:40 PM   #10
anthony7656
kegerator
Thanks for bottom brackets
I'm sure it will help 110% for me, since I already broke a piece.
X9303 2.4, CX2, Blade 400 w/ 65MG 401/9257, Trex 450SEV2 65MG,401/9560
FS ONE, G4 SIMS (2)Trex 600 CF 9451, 611, Neu 1515/H with CC 85-HV.
Love this Baby
Working on Green Earth Field Charger. Solar Panel with Battery Back up.
anthony7656 is offline        Reply With Quote
Copyright © 2004-2009 - William James - Helifreak.com
