Hi,
Right now I use the stock align charger that came with my T-Rex 450 se v2 kit. It works fine, but it takes about 2 hours to charge a pack and there is no display at all, so I think it's time for a little update. So I was wondering what would be the best option with the following requirements: - I'd like to be able to charge 2x 3S 2200mAh batteries at the same time (i dont have any plan to go to any more cells later on since my next heli will be nitro. So I dont need a 4 or 6 cells charger) - I'd like to be able to plug the charger directly in a 110V outlet at home. - I'd also like a display to see the mAh put back and maybe a storage charge setting, but I think those a pretty standard on most chargers, or am I wrong? Does such a charger exists? What are the models that do all this? Thanks for your suggestions guys. |
There are tons of chargers out there and almost as many threads discussing this topic.
My vote if for the BC6. Do a search for it and you'll find out all you've every wanted to know about Lipo chargers. Good Luck O yeah; it cost about $170, but if you look hard enough you can find some good deals.
LOGO 500, V-Bar 5.1, 4025-890, HW-120, 3X 620, 251, 10S A123 LOGO 500SE, V-bar 5.1, 4025-890, HW-120, 3X D760MG , S9254, 8S2P A123 OMG!!! It's plastic. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. What was I thinking! :-) |
#3 | |
http://www.fmadirect.com/
T-REX 450 SE V2,Beam swash,GY401,DS3400G,DS285'S,430XL, Align ESC,Sport BEC,AR6200,DX7,Cellpro4S BLADE 4OO DS285's need tail servo,motor and gyro..... Soon! BLADE CX-2 XtremeSE180's,Boomtown M3 boom,Boomtown shortened flybar,Xtreme extended upper head,Xtreme canopy,DN 850mah 15c's |
tp-1010C except you have to have a 12 volt power supply to run it. It works great otherwise and you will be able to charge 2 3s or 2 4s packs at the same time. Also get the tp-210v balancer to use along with the charger.
Maxpro X6 ! But you need a separate ps. I made mine for free from a 400watt ATX pc ps.
Couple more pics in my gallery.
-TREX600NSP - TREX500ESP - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 917540 - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 1003 - |
#6 |
After buying a cellpro 4s and being so impressed with it i bought the cellpro 10s with a/c power supply, this charger is great, two batts charge and balance out in about 40 mins, also you get a backlit display showing each cells state of charge and amount being added, top notch stuff IMHO.
#7 |
Buy, and buy it now! http://www.readyheli.com/Kong_Power_...p/kp-100w6.htm
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
Bantam eStation BC6 - charges up to 6s, has built in balancer & power supply, programmable with memories for different batteries - about US150
#9 |
The Bantam BC-6 meets all your requirements except for the 2 batteries at a time. We like many other chargers have a specialized board that allows you to have 2 3S or 3 2S packs connected in series, but the intention of these boards is that the batteries are discharged together. The 2 packs must be very close in voltage and of the same type, brand, ect...
We have our own support forum here on HF for the Bantam as well.
Evan Chapkis To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Auth US Bantam Importer & and US Service Center |
#10 |
Astro09 and a HyperionLBA 10 balancer
How much past 200 mph do I need to go you ask? |
#11 |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
+1. I use a Ripmax Pro Peak 20A power supply.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#12 |
There are lots of chargers that will charge 2 3S packs at a time.
- KongPower 100W6 - FMA Cellpro 10S - Hyperion Chargers - TP-610C I prefer the Cellpro 10S and Thunder Power chargers since they offer US based warranty and possible repair. If you are only charging 3S batteries and will never think you will upgrade. My 2 cents, is to just get 2 Cellpro 4S 4AMP chargers. These little guys rock, and 2 would be cheaper than most 6s or higher chargers!
BRIAN FLORES TREX 500: FP EVO25 6S ▪ Spartan DS760 w/S9257▪ HS-5245MG ▪ CC80 TREX 450 V2: KP 3S 25C ▪ Spartan DS760 w/9257 ▪ HS-65MG ▪ CC40 TREX 250: Outrage 800 25C ▪ Spartan DS760 w/290G ▪ HS-65HB ▪ CC25 OTHER: Spektrum DX7 ▪ AR 6200 ▪ CellPro 10S |
