Old 06-20-2008, 10:48 PM   #1
ScottKidder
Default V2 Blade grips
To upgrade my Trex 450 SE GF head to be able to use the V2 grips and feathering shaft, I would need the main rotor housing also or are the dampers just different. Just wondering because Readyheli isn't stocking the old style feathering shafts anymore. Thanks.
ScottKidder is offline        Reply With Quote
Old 06-20-2008, 11:42 PM   #2
JohnLund
Pretty sure you would need the main rotor housing too, the spindle is 4mm, as opposed to the SE 3mm.
http://www.ronlund.com/Merchant2/mer...ct_Code=HS1003
(~¿ö)
JohnLund is offline        Reply With Quote
Old 06-21-2008, 01:42 AM   #3
Plexor
HeliDirect.com has the old style feathering shaft.
http://www.helidirect.com/product_in...roducts_id=132
T-Rex 450SE V2
Futaba 6EX, HS-65MG cyclic, GY401 + S9257, 430XL + 13T, Radix 325, Gorilla Gear skids and paddles, KBDD tail blades, Boca ceramic main shaft bearings, Trueblood dampeners.
Plexor is offline        Reply With Quote
Old 06-21-2008, 10:22 AM   #4
eagleridge
Is this what you are looking for?
http://www.readyheli.com/HS1003_Feat...t_p/hs1003.htm
Kevin Williams
AmainHobbies/ProTek Field Rep
Rush700: Scorpion 4035-500kv, Vbar Silverline, CC160HV
eagleridge is online now        Reply With Quote
Old 06-21-2008, 11:37 AM   #5
pwoodyp
I heard the heads between the two are dimensionally the same
The blue colour and the O-Rings are indeed different... One O-Ring being 4mm as opposed to 3mm ID and both with an OD of 6.5mm is how they accommodate the larger 4mm Feathering Shaft of the V2.
Check the O-Ring size difference by going to ALIGN it will confirm this...
XL - O-Ring (Φ3XΦ6.5X2mm)
V2 - O-Ring (Φ4xΦ6.5x2mm)
http://www.helifreak.com/showthread.php?t=74934
pwoodyp is offline        Reply With Quote
Old 06-25-2008, 06:10 PM   #6
ScottKidder
Thanks for all the help guys
