Old 06-21-2008, 09:40 PM   #1
aongoco
Default looking for a good head speed
what is a good headspeed should i b using. i only do sport flying nothing agressive
no 3d flying yet
aongoco is offline        Reply With Quote
Old 06-21-2008, 09:42 PM   #2
george0079
something between 1700 and 1900 for sport to mild 3D
If, at first, you don't succeed, then skydiving is probably a bad idea for you.
george0079 is offline        Reply With Quote
Old 06-21-2008, 09:47 PM   #3
aongoco
right now i have 188t main gear and 11t pinion gear. running 6 cell 1700 kv motor.
i was on readyheli.com headspeed calulator. im running at 1987 head speed according to the calculator.
what should my throttle curve b at as well
thanks
Old 06-23-2008, 09:07 AM   #4
eightythree
go back down to 10 tooth. i fly with a 10 tooth doind mild 3D and the stock XL motor gets hot. i wont even try 11t being afrain that it will over work/heat my system.
eightythree is offline        Reply With Quote
Old 06-23-2008, 03:29 PM   #5
flyingtanks
I agree with eightythree. I have the stock L motor running on 10t. My headspeed at hover is 1800 in Normal mode. I fly basic aerobatics and mild 3D (flips, etc) with no power problems and nothing gets very hot. Just watch your collective use.
flyingtanks is offline        Reply With Quote
Old 06-23-2008, 05:30 PM   #6
Al Miessner
I also agree for the the type of flying you're doing a 10 tooth is plenty, i run a throttle curve
in normal of 0, 35, 80, 90, 100, my idle up back then was just 100, acrossed the bored.
now I'm running an 11 tooth pinion with the 1700 KV XL motor and the idle up throttle
curve is 92 acrossed the board. it doesn't bog and plenty of power, motor temp
  • after 3D is 135 deg F. and 6S 5000 mah battery around 126-129 deg F. you have to make sure the motor gets oild once in a while.
Flying Hard makes it fun (AnimAL)
GrandRC Team Pilot
Al Miessner is offline        Reply With Quote
