Old 05-15-2013, 09:24 AM   #1601
Greek6486
Default Re: Let's see everyones blade 400
Originally Posted by 808HeliBoyz View Post
What Tarot fbl head unit are you guys using? My son is looking to convert a Blade 400 3D he got for free to fbl. I was looking on ebay, but there were different versions for different Trex models, wasn't sure which one would be a direct fit.
The Tarot 450fl head TL45110-03 black.
sent from my RAZR Maxx w/Rage Rom
Greek6486 is offline        Reply With Quote
Old 05-15-2013, 12:40 PM   #1602
808HeliBoyz
Thanks. How did you find the conversion, you think it's easy enough for a 12 year old to do with minimal help from Dad? He's already tore down his Storm 450 and helped me rebuild my 450 3D after a crash, so he has some knowledge of the workings. Also, Ive found this on ebay, what's your take on it? Would it work? Can I trust it?
http://www.ebay.com/itm/251086565809...84.m1423.l2649
808HeliBoyz is offline        Reply With Quote
Old 05-15-2013, 01:26 PM   #1603
Greek6486
Ill have to search for the original thread that i got the info from to build it. As far as its difficulty, setting all the settings correctly is the tuff part and make sure you replace all of the servos, and balancing everything correctly. Would not recommend for a 12 year old lol!!
Old 05-16-2013, 04:01 AM   #1604
808HeliBoyz
Awesome, thanks. He wanted to do the mechanical set up his self, but I'll stand by n make sure all is being done properly. What do you think about that combo in the link I posted? http://www.ebay.com/itm/251086565809...84.m1423.l2649
Old 05-16-2013, 06:45 AM   #1605
Greek6486
Looks good however you do need some extra linkages and such, check out this thread http://www.helifreak.com/showthread.php?t=404096 that is where I got my setup basically but with a robird g31 gyro.
Old 05-16-2013, 11:55 AM   #1606
808HeliBoyz
Thanks for sharing that link. I'll look it over with my boy n see what he thinks.
Old 05-16-2013, 03:17 PM   #1607
jbobb1
Don't look like the swash and shaft will fit your 400. Looks like it's for a Trex or Tarot 450
Blade mcpx v2 Blade 130xxxxxx
Blade 450 converted to FBL
Trex 450 Pro DFC
DX8
jbobb1 is offline        Reply With Quote
Old 05-17-2013, 12:37 PM   #1608
808HeliBoyz
Ok, thanks. Woulda been nice, everything in one box like that. Thanks for the help guys
Old 05-19-2013, 11:57 AM   #1609
Jasmine2501
Location: In deep space, abandoned. Any crew? Negative.
Don't underestimate your kid - when I was 12 I was an amateur watch technician, able to take apart watches, find the bad part, and put them back together from memory. These helicopters are a lot less complicated than that. It's a good way to get your kid into understanding basic mechanical principles, which is a skill severely lacking in the latest generation. Nothing in our world is repairable, and it's eliminated a vital experience, and this hobby can re-introduce that.
Jazzy's Flight Deck:
Jasmine2501 is offline        Reply With Quote
Old 05-21-2013, 07:20 AM   #1610
LawnDartHeli
They all use the same diameter main shaft. You can use the Tarot fbl head (non dfc) and stock swash. Just change out the swash balls to the bigger Align size balls (Wow hobbies has them). That was how I converted mine some time ago.
sent from my phone using circus midgets
Tarot / Align 500e DFC (x2)
---Robird G31---
LawnDartHeli is online now        Reply With Quote
Old 05-21-2013, 03:04 PM   #1611
808HeliBoyz
Default Thanks guys
[QUOTE=Jasmine2501;5003860]Don't underestimate your kid.
Very true. When I was his age I was pretty good at taking apart and fixing truck and farm tractor motors. From a young age my son has always been good at fixing electronics like video games n radios. The only difference I see between me at that age and my boy is, if the job/fix could possibly result in sweating n sore tired muscles.....it aint get'n done, lol.
[QUOTE=LawnDartHeli;5008849]They all use the same diameter main shaft. You can use the Tarot fbl head (non dfc) and stock swash. Just change out the swash balls to the bigger Align size balls (Wow hobbies has them). That was how I converted mine some time ago.
Thanks, I think that's the rout I'll go then. Being that he got the helis for free and they seem to be sound, I don't mind putting a little money into it. This package deal looks just about the money I'd be willing to put into it.
Thanks for your help guys,
Cory
Old 05-21-2013, 06:01 PM   #1612
jbobb1
The Blade shaft and Align shaft are the same diameter, but the Align shaft is shorter on the bottom end. The Align 450 doesn't have a bearing below the main gear like the Blade does. If you look at the picture of the shaft in the listing, there's a hole at the very bottom, right where your bottom bearing sets.
Trex 450 Pro DFC
DX8
Old 05-21-2013, 08:44 PM   #1613
LawnDartHeli
Correct, you have to stay with the Blade main shaft. You can only use the head assembly ( but not the Align swash). You can however use an Align style belt tail box and get away from the crappy tail bearings and soft tail shafts. Just buy one of the many Align SE or Pro belt tail assem's (that come with the belt) and your good. It is a different tooth pitch belt, but I and many others ran the stock front pulley with no problems.
---Robird G31---
Old 05-22-2013, 12:41 AM   #1614
808HeliBoyz
Thanks, I'll try that. I have a few align 450 sport tail gear boxes that I got as spares for my sons 450 clone.
Tags
e-flite
