Old 06-24-2008, 09:48 AM   #1
Montana_Reefer
Question Can the phasing pins on the SEv2 be replaced?
Had a bad crash the other day and bent the pins pretty bad. Can I replace them or do I have to replace the entire head block?
OHC Member # 001
Outlaw Heli Club! Flying only at unsanctioned feilds!
My Thanks to Finless!!! If not for Bob I would not be where I am TODAY!!!! BROKE!!! You answer the questions for those of us who don't have anyone close to ask!
Thank You!
Montana_Reefer is offline        Reply With Quote
Old 06-24-2008, 09:50 AM   #2
DominicD
The Capi - HF Support
Yup. Get some vice grips and pull them out. Buy a plastic head and use the pins from that or make your own pins.
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is offline        Reply With Quote
Old 06-24-2008, 10:07 AM   #3
Montana_Reefer
Can I use "piano wire" from the hobby store? As long as it's the same size, then I assume you use the green locktite to hold them in.
OHC Member # 001
Thank You!
Old 06-24-2008, 11:11 AM   #4
DominicD
Its just wire, so as long as it fits in and doesnt fall out ....
Team KBDD
Old 06-24-2008, 11:48 AM   #5
JaggedEdge
Since they are hardened pins I had one break off part way into the hub. Be careful not to bend them any further when you are pulling them out.
I ran with 1 pin for a bunch of flights. Glad to have it replaced.
-TREX600NSP - TREX500ESP -
917540 -
1003 -
JaggedEdge is offline        Reply With Quote
Old 06-24-2008, 11:53 AM   #6
Montana_Reefer
Thanks guys
It looks like it's 1.5mm, so it shouldn't be to hard to find!
OHC Member # 001
Thank You!
Old 06-24-2008, 12:24 PM   #7
GreenCello
I just removed one last week and found that using a heat gun on the head made removal a lot easier.
GreenCello is offline        Reply With Quote
Old 06-24-2008, 01:14 PM   #8
Prontow
I cut up a flybar rod from my AXE CP and it fit perfect. Used green loctite to hold in, good thing about this is it is not as hard as the original and less likely to break off. Did this about six months back and have had no problem. It was a cheap fix, although my AXE did not like this so it puffed it LIPO at me! Jealous Girl!!
Prontow is offline        Reply With Quote
Old 06-24-2008, 06:21 PM   #9
kahn10
making new ones out of drill bits seemed to work really well for me.hard as all hell and i used slightly larger ones as there seemed to be a little slop with the old ones
kahn10 is offline        Reply With Quote
Old 06-24-2008, 08:16 PM   #10
WBFAir
Sorry to be revealing my ignorance here, especially since I've already built and been flying a V2 for a few months now but hey if you don't know....ask right
What the heck is phasing pin ?
WBFAir is offline        Reply With Quote
Old 06-24-2008, 08:16 PM   #11
DominicD
The two pins that force the washout to spin with the head.
Team KBDD
Old 06-24-2008, 08:19 PM   #12
WBFAir
Oh OK I had a feeling thats what they were (honest) I just didn't know that was what they were called.
Old 06-24-2008, 08:20 PM   #13
DominicD
I call them anti-rotation pins, not sure they have an official name.
Team KBDD
Old 06-24-2008, 08:35 PM   #14
ZzEther
I've never had any break but had 'em twisted pretty bad. I just get on them with a needle nose and keep tweaking them until they're straight and smooth-sliding again. They should sell these with those TINY set screws that tighten them in a little baggie.
TRex 700NP FBL | TRex 600NSP FBL | TRex 550E FBL | TRex 450 Pro FBL | TRex 250 | SJM430-C "E²" FBL
ZzEther is offline        Reply With Quote
Old 06-24-2008, 08:51 PM   #15
Rick Rotorhead
Yeah, I just straightened mine with pliers too.
450SE Silver - Power: Neu1107-2Y + 10t pinion ESC: Jazz 40-6-18 Governed. - Batts: 4s, FP 2100 Evolites. Pitch +/- 12* (TC63 PC 0,25,50,75,100), cyclic 6* HS2900
HS65Mg x3 + GY401 + S9650 tail.... Rx: AR6200 - Tx: FF9Super(T9CP) +Spektrum Module
Crash count = 13 for 179. Trex time aloft = 22:42
Rick Rotorhead is offline        Reply With Quote
Old 06-24-2008, 10:04 PM   #16
TPOG
It's just next to the flux capacitor...
Copter-Rex 450 ;-) Scorpion 10 on 4 cell, HS 65MGs, 9650/9257, Logictech 2100T. CF boom, blades, paddles and tail pushrod, K&B tail blades, Futaba 7C Tx
TPOG is offline        Reply With Quote
Old 06-24-2008, 10:09 PM   #17
Montana_Reefer
Thanks guy for all the answers.
I've used pliers before a couple of times to fix them and just did it again tonight! But I'm pretty sure this is the last time for one of the pins on there. I'll be picking up some 1.5mm paino wire and cutting some pins for the parts box before the weekend!
OHC Member # 001
Thank You!
Old 06-24-2008, 10:11 PM   #18
Montana_Reefer
OK........McFly!
OHC Member # 001
Thank You!
Old 06-25-2008, 08:49 AM   #19
WBFAir
Actually I've been thinking of putting one of those on my Trex and hook it up to my throttle hold switch so that I can send it back in time to the moment just before I lost control and crashed it.
Good idea ?
Old 06-25-2008, 08:55 AM   #20
Montana_Reefer
Now your cooking w/ fire!
That's the best idea I've heard! Boy will I get back some money on parts!
OHC Member # 001
Thank You!
