Old 07-06-2008, 12:10 PM   #1
brettboz
Default Unknown source of shaking
I had a very small crash over the weekend and it now shakes quite badly after about 60% throttle (really noticeable in idle up).
Anyway I have changed the flybar and main shaft, both were bent. I have changed the feathering shaft although it was straight (its an align trex one). I have changed the blades although the others were not damaged in the crash. I have retracked the blades and pitch is perfect +10/0/-10.
Visually I cant see anything which would cause the shaking, any ideas please?
brettboz is offline        Reply With Quote
Old 07-06-2008, 12:14 PM   #2
Stinky Igloo
Check your tail shaft and tail hub. They bend easily.
Make sure your flybar is centered and the paddles are level with the flybar frame.
-Marc
Vibe Fitty | Six Hundo
find ~/midichlorian +20480M
Stinky Igloo is offline        Reply With Quote
Old 07-06-2008, 12:23 PM   #3
brettboz
Flybar is level and centered. If I take the blades off I can spool to 100% with no shake. Therefore I ruled out the tail... but could it be this.
Also just reading some of the other threads and others have the shakes and live with it, well mine flys and doesnt seem that bad flying, just annoying, should I live with it too?
Old 07-06-2008, 12:28 PM   #4
josh mcormick
Oh and you said you changed your flybar shaft, Ive had about 35 wrecks since ive owned this bird and i just bend my shaft back, with no vibrations what so ever, As long as you get it pretty strait and level with flybar cage, you will be fine, Dont replace parts that arent bad, this hobby cost to much as it is. Also im sure you balacnced your main blades, but wont hurt to double check, good luck
josh mcormick is offline        Reply With Quote
Old 07-06-2008, 12:44 PM   #5
Stinky Igloo
If it shakes with your mains on, but not off, your blades are not balanced.
Also check your blade tracking.
-Marc
Old 07-06-2008, 01:22 PM   #6
brettboz
Done both, blades are tracked and balanced. I spent a lot of time on that issue today and I am pretty sure they are as good as it gets.
Old 07-06-2008, 01:23 PM   #7
brettboz
Originally Posted by josh mcormick View Post
+1
I have changed out about 4 flybars so far, it seems to be my weak spot.
Old 07-06-2008, 01:24 PM   #8
Stinky Igloo
Yet, when you remove the main blades the vibration disappears?
-Marc
Old 07-06-2008, 01:28 PM   #9
brettboz
Just realised something, I have tracked them but not balanced them. How can I balance the blades???
Old 07-06-2008, 01:33 PM   #10
Stinky Igloo
You could buy a blade balancer, then add clear backing tap to add weight as needed.
OR
Make your own.
Both methods, clear packing tape to add weight as needed.
Also balancing blades is a two part process, you need to first make any corrections to the CG of the blades to get them equal, THEN balance with a balancer.
Note, that the e-flite 400 blades are pretty bad when it comes to balance IME. Switch out for some align 325 pro woods worlds better in terms of quality and performance.
-Marc
Old 07-06-2008, 02:04 PM   #11
josh mcormick
They rod acually breaks? Iv'e had my paddles wraped around each other, many of times and just bent back and had really god luck so far, Knock on wood. Maybe they cheapend up the steel a little more. The chinese must have thought the 5 cents they had invested in the metal was to much. I even salvage most my spindles by bending back, and end up with perfect tracking, I am currently laid off so got to make do with what i got. Good luck Brettboz, I'm sure you will find it soon
Old 07-07-2008, 12:37 AM   #12
notreallyme
watch this it may help http://video.helifreak.com/?subpath=...lancing101.wmv
Notreallyme
notreallyme is offline        Reply With Quote
Old 07-07-2008, 05:02 AM   #13
brettboz
Blades now balanced.... problem fixed....
The brand new blades had very different centre of gravity and very different weights. What a mess no wonder it vibrated so bad. I can't believe they make them so bad.
Old 07-07-2008, 10:56 AM   #14
Redfire SVT
Preaching to the choir, try the Align Pro Woods- you will love them.
Redfire SVT is offline        Reply With Quote
Old 07-07-2008, 11:29 AM   #15
Swashmix
Tried them for the first time this weekend. Very neat quieter sound. More stable on the hover. Kept a given altitude better too. Throttle input seemed more sensitive too.
Swashmix is offline        Reply With Quote
