Old 07-11-2008, 02:28 AM   #1
ipjodan
Default Hitec HS-5245-MG for cyclic
Hi all,
Im researching for a 500 build (yeah baby) I was fed up with replacing the gears in my HS-56's in my 450 so i went for the HS-65-MG and have never had to change gears yet. Are the 5245 what im looking for for the 500? I fancied the 9650 but like the price and MG of the 5245
MCPX V2 Stock, BL MCPX HP05 HP03, DX6i
TREX450 SE V2 DFC, 35X, 2221-8 12T , BEASTX, HS65MG, HSG5084MG, R617FS, 7C
Team Taco Pilot
ipjodan is offline        Reply With Quote
Old 07-11-2008, 04:07 AM   #2
Laurens
From what I hear you won't be replacing gears, but cases. I'm not sure thats the upgrade you're looking for.
Team Thunder Tiger Europe
4RC.nl, Edge rotorblades, Scorpion systems
Laurens is offline        Reply With Quote
Old 07-11-2008, 04:57 AM   #3
psindrup
Originally Posted by ipjodan View Post
Hi all,
If you use the 5245MG, just don't use the blue metal arms that comes with them. They will send all the "crash force" directly into the servo, and break the case instead.
Peter
psindrup is offline        Reply With Quote
Old 07-11-2008, 06:16 AM   #4
perfeet
You can get new cases at http://flying-hobby.com/catalog/product_info.php?products_id=2953 for 3.70$ each.
I got two, just in case...
Regards perfeet
- Mikado Logo 600SE (Vbar 5.0 and 12S)
- Parkzone Habu (5S)
- ArtTech Wing Dragon Sportser
perfeet is offline        Reply With Quote
Old 07-11-2008, 06:40 AM   #5
RZ350Freak
I read someplace, can't remember where now, that hitech fixed this issue with the week top servo cases. Anyone know if this is actually true?
RZ350Freak is offline        Reply With Quote
Old 07-11-2008, 06:47 AM   #6
psindrup
They made a "fix", but according to actual user reports it did not solve the issue.
Peter
Old 07-11-2008, 06:59 AM   #7
warpspeed
Team Tostada Member
Yes, I can confirm that. The new versions still break exactly at the same spot as the old.
Switching to plastic arms didn't help, either.
Save yourself the frustration and go with the 9650's. Or HS82MG's.
The name's Doug. I carry a gun 'cuz a cop is too heavy
warpspeed is offline        Reply With Quote
Old 07-11-2008, 07:19 AM   #8
xahhax
they may sell cases, but in case you actually have not bought the servos yet, go for something else than the 5245...i deeply regret this choice.
Trex 500, HS5245MG, JR770, JR3500G, Scorpion 3026-1400
Trex 700N-1, 8717, JR770, JR8900G, OS 91 HZ
Trex 700N-2, DS610, Spartan, DS650, OS 91 HZ-PS
Outrage 550, DS620, Quark, DS650, Scorpion 420-1390
xahhax is offline        Reply With Quote
Old 07-11-2008, 07:32 AM   #9
Socal500
Just stay away from the 5245. Even if the case did not break, the servo itself is not that great. There are better choices. Not using the metal arm will not save the case unless you weaken the plastic arm so your sure it breaks first. That would be a trial and error process and just hope the error does not happen in flight during a hard 3D manuever
9650 is a good choice and convert to metal gear if you can find them. JR makes a metal gear servo. Priced higher but probably worth it in the long run, especially if you want a drop in solution.
Socal500 is offline        Reply With Quote
Old 07-11-2008, 07:37 AM   #10
nickolai
if you drill thru the embossment that breaks with a 1mm bit and replace the shaft with a longer piece of music wire so it sticks out of the case a mm or so, it solves the case problem. i have crashed 3 times since i did the mod and i have yet to break a case
nickolai is offline        Reply With Quote
Old 07-11-2008, 07:46 AM   #11
Skint Eastwood
http://www.hobbycity.com/hobbycity/s...idProduct=6756
best of both worlds can highly recommend them
Skint Eastwood is offline        Reply With Quote
Old 07-11-2008, 07:48 AM   #12
Skint Eastwood
or you get the same effect the expensive way and buy 9650s and replace with these metal gears http://www.hobbycity.com/hobbycity/s...idProduct=6757
Old 07-11-2008, 07:58 AM   #13
Skint Eastwood
the mks come out a slightly faster speed i believe
Old 07-11-2008, 08:34 AM   #14
psindrup
Originally Posted by Socal500 View Post
JNot using the metal arm will not save the case unless you weaken the plastic arm so your sure it breaks first.
How can you tell? Have you tried the plastic arms and crashed since?
I replaced the "bling" blue metal arms with the tiny black arms that comes with the T-500 kit before my first crash, and all 3 servos and arms survived without a scratch.
Of course I can not say if they would have broken with the metal arms. I am only saying that it is possible to crash the 5245 servos without breaking the servo casings.
Peter
Old 07-11-2008, 08:49 AM   #15
RZ350Freak
Too late for me, I bought 3 of them.
My issue, I think, is that they don't seem to move at the same speed. When I do full pitch pumping the heli starts to veer off in one direction. Even if I have it in a fast piro and start full neg to pos pitch pumping it will still lean to one side right after I start to come back up from -12.
I am relatively new though so this could be my set up for all I know but it bothers me for sure.
Old 07-11-2008, 09:00 AM   #16
Scotty T
I came up with the perfect solution for this...
I was sitting at my engineering bench, drawing, testing, breaking, stress tests, and doing many scientific experiement with these little units.
The conclusion.....
Don't crash!
Scotty T is online now        Reply With Quote
Old 07-11-2008, 10:52 AM   #17
terrabit
I just bought a set of JR 3517 MG's. These are going to be the midsize servo of choice. .09 sec/51 oz/in @6v, with MG gears.
They're spendy but, after paying for a set of 5245's and several replacement cases, I'll gamble that they're worth it.
I've never had anything but good experiences with JR products and they offer a 3 year warrantee.
You can get them at http://www.rchobbysports.com/ in Seattle, WA. Also the guys down there are very helpful answering questions.
terrabit is online now        Reply With Quote
Old 07-11-2008, 12:19 PM   #18
ryem3
Which servo is that? I don't find a JR 3517 anywhere. I see a 8317 heli servo for $100 each (!), but these look pretty big for a 500. The 3650's seem to be a popular choice, but they are $75.
ryem3 is offline        Reply With Quote
Old 07-11-2008, 12:29 PM   #19
ryem3
Never mind, I see RC Hover has them for $85 each. Shouldn't these prices be going down?!
Old 07-11-2008, 12:37 PM   #20
Ultraviolet
$10 more than a z3650 just because the label is different. .....and it is now an "air" verses "surface" servo.
Ultraviolet is offline        Reply With Quote
