Old 07-11-2008, 09:38 AM   #1
cfmorrell
Default I took the plunge (and need some help with gyro location)
So, I've been flying coaxial helis for a while, and finally decided to take the plunge and get myself a CCPM heli. I went back and forth between the 450SA and the Blade 400 for months, but decided that if I went cheap, I would regret it in the long run, so yesterday afternoon I brought home my shiny new T-Rex 450SA. I got 65mg's, 9650 on the tail with the 401 gyro, and I've got a DX6i with the AR6200 RX.
So I'm working through the setup of the heli, and am running in to the issue of where to locate all of the electronics on the frame. I know this has been over in many other threads, and I've read through them, but had a new idea that I wanted to run past you guys. Align says to put the gyro in front of the motor, but Futaba says no closer than 10cm. The only place on the frame that's more than 10cm away is on top of the boom. I was thinking of compromising, and putting the gyro on the very back of the bottom plate of the frame, right where the receiver is supposed to go. The receiver fits almost perfectly in the little flat spot between the frame rails under the boom, and the esc will either go up front where the gyro would have been, or between the gyro and motor. Any thoughts on if these locations will work, and work well? I definitely don't want the gyro on top of the boom, as I'm afraid of the consequences of a newb pilot. Thanks for the help, and I'll post some pics once it's together.
cfmorrell is offline        Reply With Quote
Old 07-11-2008, 09:45 AM   #2
[X]Outlaw
You can mount it under the boom with Rick's SA gyro mount
http://www.wavelandps.com/clearly/
Scroll down to "NEW! Trex SA Inverted Gyro Mount:"
[X]Outlaw is offline        Reply With Quote
Old 07-11-2008, 09:49 AM   #3
Hotwings
hoave a look on my gallery "Hotwings" on RR and look at the se with the 401 on top of the tailboom block, i have since moved it to the bottom, it will work just fine on the area that you want to put it. Ron
"Learn from others mistakes, you can't live long enough to make them all yourself"
Hotwings' sensors, Robbe 90 Heli's, Nova, Mille III, Futura SE (2)Predator Gasser
T-rex se Silver CF, T-rex 450x SE'fied night bird, T-rex SE black CF, Raptor 30os37
T-rex 600 HFE Rotorworkz,#2 T-rex 600 HFE Rotorworkz, Tiger 50 w/hyper 50
T-rex 600 Nitro Pro, YS-50, MP-5, 6100t, 9255's,Futaba 14MZ 2.4 & 72mhz
Hotwings is offline        Reply With Quote
Old 07-11-2008, 09:53 AM   #4
TomRex
Please don't reinvent the wheel, there are ways to install your electronics but the main key is to install them with no adverse reactions between components. The installation can work any way you want to but the standards that work well and with no problems are within the forums.
The Align instructions seem to be a so so guide but only on paper not in reality!
How much past 200 mph do I need to go you ask?
TomRex is offline        Reply With Quote
Old 07-11-2008, 02:36 PM   #5
electricdurango
AAAHHHHHHHH!. Is that a "Z-bend"? You scared me!
electricdurango is offline        Reply With Quote
Old 07-11-2008, 03:19 PM   #6
JEB123
No way, it's a double L bend.
Spektrum DX6i, TRex 450SE V2 black , Scorpion 2221-8, Heliartist N23CP Hughes500D
TRex 450SE V2 silver, Scorpion 2216-12, w/Spidergear, DarthDark Hughes300C, Blade MCX, HK-450, Cessna 182 foamie, 2 AR6100
If it ain't broke, fly it...
JEB123 is offline        Reply With Quote
Old 07-11-2008, 08:41 PM   #7
alienteabagger
Zit: T-Rex450SA w/ 430L 13t pinion - My flying backscratcher
Tiny: Raptor .50 w/TT .50 engine - One bad machine!
One DX6i to rule them all!!
Have a gyro/tail/wag problem? Check here
alienteabagger is offline        Reply With Quote
Old 07-12-2008, 04:47 PM   #8
JEB123
Originally Posted by alienteabagger View Post
Thank you, thank you, I'll be here all week. Try the potroast.
