Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 07-11-2008, 09:12 PM   #1
JMP
Question CPP to CP
This may have already been posted somewhere. If so, please direct me to the appropriate post.
I want to convert an E-Flite Blade CP Pro to a non-Bell-Hiller Blade CP.
1. Can this be done?
2. If so, what parts do I need to purchase to make the change?
3. If this conversion won't result in an easier, fun to fly heli, please let me know.
Someone will likely ask "why". The answer is, I want a more docile heli to fly for relaxation instead of flighting the antics of the Pro. My parts conversion request may not be the answer, but I have already invested in the Pro and can't afford to buy another heli. I have heard from someone at one of our LHS that the conversion is possible. I just need some more specific parts help.
Any help with the parts request (if this conversion is not too stupid an idea) would be appreciated.
Thanks,
JMP
JMP is offline        Reply With Quote
Old 07-11-2008, 09:52 PM   #2
Slyster
Wouldn't it be easier to tame it down via the radio? (headspeed, cyclic expo, etc)... or can't you on that one? I was thinking of my Blade400... I got it like a big honeybee FP right now.
Slyster is online now        Reply With Quote
Old 07-11-2008, 09:54 PM   #3
HeathH
you cannot tame it down in the stock radio. the closest you can get to taming it would be to add more flybar weights. i started with the non bell/hiller upgrade and couldnt really tell the difference between the two. and i hate to drop the bad news but the blade cp can never really be tamed down it is just the way it is.
HeathH is offline        Reply With Quote
Old 07-11-2008, 11:34 PM   #4
JMP
Thanks, guys. That was the advice I was looking for. It isn't really practical and I'd be no better off. The added flybar weights might help to tame it a little. It was a bad choice to begin with, but I didn't know about HeliFreaks then. Now I do and I am working toward getting my B-400 mastered. I can already tell the B-400 is a lot more stable in the air. I suppose I was just trying to make the best of a bad investment.
Many thanks,
JMP
Old 07-16-2008, 10:13 AM   #5
tyrick69
Default Taming The CPP
You should be able to tame it a little by adding the non-Bell Hiller mixer from the CP+ and flat bottom blades.
tyrick69 is offline        Reply With Quote
Old 07-17-2008, 12:14 AM   #6
Kindling Maker
Add some weight to it and it tames alittle bit. I wanted to tame mine with a D-9 dozer nost of the time, but that is my cure for everything.
This is going to hurt,,,OR be expensive.
CCP,3xCX2,B-400,mCX
Walkera #38
Skylifter Tandem
Kindling Maker is offline        Reply With Quote
Old 07-19-2008, 03:30 AM   #7
scm6079
Personally, I would just invest in a cheap set of the flat bottom blades, and add more flybar weight. That will tame it down a little on the cheap, as you save up for a B400, Trex 450SA or the like.
-Scott
CX2, CPP, B400, Trex450SA, Trex450XL, Trex450SEv2, Trex600
scm6079 is offline        Reply With Quote
Old 07-23-2008, 08:27 AM   #8
odam2k
I can confirm that adding a second set of flybar weights, and making sure everything is balanced and tight makes the CP Pro much more stable... I'm three weeks into this, and am starting to learn head-in hovering now...
odam2k is offline        Reply With Quote
Old 07-26-2008, 11:24 PM   #9
olendorf
Try moving the servo linkages 2 holes farther in on the two rear servos. That will make it a lot less sensitive.
olendorf is offline        Reply With Quote
Old 03-02-2009, 11:37 PM   #10
Snapper0923
I thought I was just getting better at flying my CP Pro. Turns out the linkage has loosened up a bit since it was new 3 weeks ago. Tonight, I found a tech link that reminded you to tighten every screw after general use and crashes. So I tightened everything... too much. I flew the CP Pro right after and it was as squirrelly as a.... squirrel. So I loosened up the center see-saw linkage on each side which control the flybar, and that put the CPP back to being as controllable as I've had it.
I think the CPP is a good machine, albeit pretty squirrely in general. Can't wait to fly me Blade 40 when it gets delivered tomorrow or wednesday.
Yee Haw!!!!
Snapper0923 is offline        Reply With Quote
Old 03-03-2009, 12:37 AM   #11
Jasmine2501
Location: In deep space, abandoned. Any crew? Negative.
The CP Pro is a decent heli, but you'll like the Blade 400 a lot more - it is a whole world of difference.
The best thing you can do with the CP Pro is convert it to Spektrum and change the pitch and throttle curves around. If you raise the head speed it will fly better, and you can also do what I did and take the lousy gyro from the Blade 400 and put it on the CP Pro with a direct-drive tail. Then get a GY401 for the Blade 400 - also makes a lot of difference.
Jasmine2501 is offline        Reply With Quote
Old 03-03-2009, 01:44 PM   #12
cold duck
Just add a set of SuperSkids and plasti-blades to tame your twitchy little bird. You can always remove them after you learn how to fly it better. Easy easy easy!
cold duck is offline        Reply With Quote
Old 03-03-2009, 07:07 PM   #13
helidude3
T-rex 250 Super Combo w/ hs-65mg's
Blade cp pro: spectrum receiver, BL main, DD tail, Gyro
www.bladecpupgrades.co.nr
Blade cx2
E-flite 4-site
helidude3 is offline        Reply With Quote
Old 03-09-2009, 02:45 PM   #14
WickedDragon
Originally Posted by helidude3 View Post
+1
and fly bigger batteries!
To answer your question...... yes you can convert back to the original head. You just need the original blade grips and change the spacers.
If you want it more stable rather than "tamer" put the aluminum head and swashplate upgrades on....... much better to fix the problems than to mask them!
Doug Bonham, WickedDragonRC
Gravity isn't just a good idea, it's the LAW!
TRex450SE DFC; TRex450Pro DFC; TRex500 DFC Pro; TRex600N DFC's; CHP-TRex600eDL DFC; Trex700e DFC Pro
WickedDragon is offline        Reply With Quote
Old 03-10-2009, 11:28 AM   #15
dabigrussian
Thanks,
JMP
hey bro,
here's what Ive done to make it 'better' - stable and such might be alot to ask for a beginer but as you get better, some like the CP more and more. I added the flat bottom platic blades to mine - they are almost indestructable! And took out the 0-ring dampers, replaced them with neon green fuel tubing cut to fit. this gave a much smoother feel to the controls, and made the response in cyclic a little slower, I also added flybar weights so there are 3 weights on every flybar. then added G110 gyro for tail (much better, but still need to add to Direct Drive conversion I feel), took 2 sided servo tape and wrapped it around the skids to add cushioning to hard landing - i guess the extra weight from all the above helps smooth it out and make it easier to hover and do simple circuts. I fly in a small room so I need it smooth! Good luck!
dabigrussian is offline        Reply With Quote
