Belt CP E-Sky Belt CP
Old 07-11-2008, 09:04 PM   #1
wherndon
Default Grub Screws will not come loose
I am trying to install CNC parts and have run across where the grub screws in the OEM plastic tail and both on the OEM flybar will not break loose. I have bent both of my 1.5mm allen wrenches. I have soaked the flybar grubs in a bottle of polish remover(acetone) for 30 minutes and they still will not come loose. They must have used permanent loctite when assemblying the components at the factory.
Please help!!!!
Wayne
Belt CP - CNC Head, CNC Tail, TRex Canopy, Heli-Max MX400 Main Gear, Telebee HH Gyro, Mystery 30A ESC, Tower Pro SG90 Tail Servo, Carbon Fiber Tail Boom, HDX Blades
wherndon is offline        Reply With Quote
Old 07-12-2008, 02:18 AM   #2
copterboy
Have you got any spare shafts and a steel bit for a jigsaw? Only kidding...lol!
Mine were on real tight, but managed to get them off after a bit of a fight. I was using the L shaped allens at first, but then I borrowed a good allen wrench (like a screwdriver). The extra leverage was all I needed.
If you don't know anyone who has one then maybe try taking it down your local hobbystore and ask the good assistant for some advice and a demo of how good their tools are? Tell them your thinking of buying one and want to see if it works!!! LOL
COPTERBOY DX6i, mSR (SOLD), BeltCP (SOLD), mCPx w solid boom and Rakon Heli Head
T-Rex450V2 w.PRO head, Scorp-8 & 45A V2 ESC, CSM4200/S9257, 3xHS65MG
E-Flite CX2 - All Microheli/Extreme CNC CF Upgrades
TRex600N, Kasama Head, OS50SX
copterboy is offline        Reply With Quote
Old 07-12-2008, 03:04 AM   #3
Ber60
Also heat will help to loosen screws (soldering iron, bic, flame thrower )
Anything that flies
Ber60 is offline        Reply With Quote
Old 07-12-2008, 03:36 PM   #4
copterboy
I've got a plumbers torch you can borrow! May have to use it myself to get screws out of cnc tail section, need to replace belt and shaft and couldn't get them out earlier today.
Thought I'd come back here to find if any more suggestions were posted. Sod's law eh!
Old 07-13-2008, 09:00 PM   #5
nitsuj
As a last resort, I guess you could try drilling them out
nitsuj is offline        Reply With Quote
Old 07-15-2008, 04:04 PM   #6
Ian 777
If you drill them you bung the threads, a pointed bit in a soldering iron will get them out, But be careful not to melt the plastic
Trex 500 ESP
Phoenix Flasher 450
Frankenbelt
Ian 777 is offline        Reply With Quote
Old 07-15-2008, 08:21 PM   #7
copterboy
Just used plumbers torch to disassemble CNC tail section!
Held it with some pliars high above flame then lowered it down closer a few times, for a few seconds each time. It worked but very crude method. Didn't have to worry about the plastic pulley & belt as these were both being replaced. I think if your tryin to keep yours safe, try the soldering iron method, as this will apply the heat directly on the screws!
Old 07-16-2008, 10:14 AM   #8
DierWolf
Not a crude method, its THE method to loosen loc-tited screws.
Esky Esmart 600
EXI-450 with Scorpion Motor
Esky Belt CP with Direct to Swash Mod & Trex V2 Head/tail
Esky Belt CP with DTS Mod and full esky cnc head/tail
Esky Belt CP w/Airwolf Fuse (Sold) / Esky Lama V4 Full modifications.
Art-Tech Wasp V3 Heli & Art-Tech P-51D w/brushless motor.
DierWolf is offline        Reply With Quote
