| 600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Just finished my Trex-600 nitro pro
Using four JR 8717 servo three for cyclic and one for throttle. Using a JR8900g and a solid G gyro. Using a YS 50st Using Multi-Gov Pro And much more. I just hope it flys????
Bill Burke |
Looks good to me but the fuel clip needs to be on the fuel line to keep from shaking off there whether you are using it to clip or not. That isn't the stock fuel line right?
Field Representative for To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Got one on it's the yellow one if you can see it. I am using the clip that came with it for a fuel line plug. I will be getting a much better one to plug the line before it flys.
Yup not the fuel line it cane with it's the good stuff. Also using hayes black chunk line. I have set it up for 14 -14 on pitch brought down to 12 -12 for now in the swash mix. Running cyclic at 7 degs hope its not to much for its first flight. Also have the new oneway, metal bearing blocks, frame stiffeners, metal fan, UK swash and washout. Also installed a second tourqe tube bearing. Just in case.
Bill Burke |
It won't be too much 600n flies so nice. Sounds great and it looks awesome.
Way cool, wanna race? I bet I can run over there and hug mine before you can.......See...... I beat ya.
600NSP MultigovPro, DS760 w/BLS251, 4-9452's & HS65 Trex 450 SE V2 GY401w/9650 & 3 HS65MG GWS Dragonfly Futaba 9C |
#6 |
Man, that canopy is sweet! You should get one of the new blue booms. It would go great with the blue checker pattern. The red boom sort of clashes. Hmm, maybe we need a "Heli Fashion" thread or does that sound just a little too gay? Anyway, good luck with your maiden!
AMA# 902812 More stuff than there is time to fly it. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 |
please flyers....if you are new to helis or even a new kit...have somebody take a quick look...i learned my lesson...it will save you money
learning is half the battle
T-rex 600 N Pro GY611 with BLS251 GV-1; BLS451 OS 50 HYPER, Hatori Bob Watts Pipe TT 600 Carbon Blades |
