Go Back   HeliFreak > R/C Helicopter Support > Avant RC - Mostro & Aurora
Avant RC - Mostro & Aurora Avant Mostro, Aurora, Electric eAurora, RigidCore Flybarless Head, Avant EFX and Avant FX Helicopter Support
Old 07-19-2008, 01:05 AM   #1
nosler130
Angry Main bearing and gear
Help,
After 1 gallon i have had to replace the clutch sprag and the main sprag bearings????
After a futher 1/2 gallon i think the main sprag is on its way out and the main gear seems to be running out of true it has a high spot against the drive pinion, bought a new gear and i have tried them both on the main sprag hub in every position but still a high spot????
Do i need a new hub??????
JJ
nosler130 is offline        Reply With Quote
Old 07-19-2008, 03:40 AM   #2
Augusto
The issue you're having can be fixed by slotting the two holes on the ratio plate that hold the ratio plate to the frames very slightly only about 0.25mm in the direction that increases the space between the pinion and the main gear. The new kits have the ratio plate already spaced with the additional 0.25mm of spacing. You will also notice that the starter shaft alignment is much better and it minimizes slipping when starting.
Augusto.
Augusto is offline        Reply With Quote
Old 07-19-2008, 06:44 AM   #3
nosler130
Thanks Augusto for that i will do that,
But does not explain my problems with the main one way bearing??
JJ
Old 07-19-2008, 03:20 PM   #4
nwolsink
Augusto.
Please inform when the "new" kits are shipping
SPEkTRUM DX8
TREX600NSP VStabi V5.3 / 55HZ
TREX700N DFC/3Gx/ 105 HZ-R
nwolsink is offline        Reply With Quote
Old 07-19-2008, 04:30 PM   #5
rl_sexton
They are already shipping I have one in the mail.
rl_sexton is offline        Reply With Quote
Old 07-20-2008, 11:35 AM   #6
nwolsink
I am in Europe so let's hope there are some kits on their way to Midland Helicopters.
Augusto, can you confirm there are Aurora's moving to Midland?
SPEkTRUM DX8
