Old 07-25-2008, 03:52 AM   #1
Roger_15
Default Help with head setup please.
I seem to have a problem that won’t go away. I’ve watched all the videos, multiple times, but I’m getting nowhere.
I “think” the swash, washout arms and fly-bar cage are all level but I come up with different blade pitch readings on opposite sides of the heli. On one side, I come up with 10-0-10 and on the other side, 8-(+3)-12, or something close to that.
I leveled the swash and was able to get it perfect through the entire range of movement using the t-rex tool so I think that it is correct. The other two I have to eyeball.
Here are some pix and please let me know if you see anything that I am missing. I can’t seem to figure it out.
Thanks.
Roger.
Pix are at half stick.
Edit: Pix show opposite sides.
ID:	56298   Click image for larger version
Roger_15 is offline        Reply With Quote
Old 07-25-2008, 04:32 AM   #2
Helidude2
Check the lengths of your pitch control rods. They should be the same length. Have you tracked the blades?
Helidude2 is offline        Reply With Quote
Old 07-25-2008, 08:07 AM   #3
Roger_15
Sorry, I should clarify here a bit. When I measure the pitch of my blades, I do both blades on one side of the heli. Then I turn the heli around and do the same on the other side. This is where the problem is. On one side with “both” blades I get perfect pitch readings. –10 0 +10. When I do the other side of the heli, I get a different reading and it’s off by maybe 3 or 4 degrees. I believe it has been this way from the beginning.
I hope this makes sense.
Thanks.
Roger.
Old 07-25-2008, 11:09 AM   #4
johnbs8
that sounds wierd. what does it do in flight? is your tracking off?
johnbs8 is offline        Reply With Quote
Old 07-25-2008, 01:36 PM   #5
Roger_15
Thanks John, she flew okay I guess but I have only been hovering. I tested her when I bought the pitch gauge, and I know it was off then. Not knowing what the heck I was doing, I didn’t try to fix this until now…after installing the new servos.
I have looked closely at the head and I can’t see anything wrong with it. As the picture shows, the swash, washout and flybar all look fairly level. There is no binding that I can detect so I am at a loss.
The only thing I haven’t touched yet is the wash out arms, but they seem okay. Like you said, it seems odd and I am hoping someone has had these systems also and has a fix.
If anyone needs them, I can post more pix or even a movie.
Any help would be appreciated.
Thanks.
Roger.
Old 07-25-2008, 03:09 PM   #6
sokal
look the the mixer the longer side points away from the blade it controls
B400 DS285/3400G/401/-8/40Aesc/sonicCNC/CNCframe
TwinRexx: 6xHS-65/2xGY240/jfg500/TH2
CH-47D/UH-1H Crewchief/ Mechanic
sokal is offline        Reply With Quote
Old 07-25-2008, 03:13 PM   #7
sokal
need a pic with the blades across the body with a side view shot of swash and head
Old 07-25-2008, 05:01 PM   #8
Roger_15
Thanks Sokal for your help.
Here are the pix you asked for and a couple more. If you need anything else just ask and I will try to get them up for you. All pix are at half stick and 0 pitch.
Roger.
ID:	56359   Click image for larger version
ID:	56360   Click image for larger version
ID:	56361   Click image for larger version
Old 07-25-2008, 06:26 PM   #9
sokal
at a concert using my phone to help need a side proile with blades of to the side so I can see the siscor arms ball linksI saw your pics look like one side of swash is low need a closer side pic thanks
Old 07-25-2008, 06:28 PM   #10
sokal
hit me up on msn messanger for a direct chat and pic send sokal88@hotmail.com
Old 07-25-2008, 07:42 PM   #11
sokal
sry msn not workingwill help after
Old 07-25-2008, 07:55 PM   #12
Roger_15
Thanks Sokal, enjoy the concert! This can wait till tomorrow anyway.
I sent four pix to you and just let me know what you think. I am on IM as well under the same username as here@ hotmail.
Thanks again!
Roger.
