Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Old 07-27-2008, 09:38 PM   #1
jratliff
Default Eflite mini Funtana X balance
So I bought this aiplane this weekend...... and now I remember why I quit planes! Does anyone have any experience with this plane? I followed everything in the directions to a tee (which were sparce) and it will not balance!!!!!! It is relay nose heavy. Any ideas guys? The lipo is as far back as it will go. Thanks guys!
jratliff is offline        Reply With Quote
Old 07-27-2008, 10:37 PM   #2
invertmast
move your reciever and servo's around if you can. add some lead weight to the tail, etc etc etc
Comparf Eurosport
1/7 F-14D
Rave 450, scorpion -10, DS285MG, 3500G, Spartan, 4s 2200 outrage, 6100e, 350mm radix
lookin for another Vibe 50
invertmast is offline        Reply With Quote
Old 07-29-2008, 09:58 AM   #3
DierWolf
Common Sense.... Move what you have to to get the proper cg which is
from teh manual Quote :
The recommended Center of Gravity (CG) location for the
Mini FuntanaX is 3
3/4" (95mm) behind the leading edge
of the wing against the fuselage.
Esky Esmart 600
EXI-450 with Scorpion Motor
Esky Belt CP with Direct to Swash Mod & Trex V2 Head/tail
Esky Belt CP with DTS Mod and full esky cnc head/tail
Esky Belt CP w/Airwolf Fuse (Sold) / Esky Lama V4 Full modifications.
Art-Tech Wasp V3 Heli & Art-Tech P-51D w/brushless motor.
DierWolf is offline        Reply With Quote
Old 07-29-2008, 01:59 PM   #4
jratliff
Default I can't believe it.........
Someone on RC Groups mentioned the little carbon sticks for the horizontal. These things are tiny! Like the lead of a pencil small and about 5" long. I epoxied them under the stab and I'll be danged...... it balanced.
Egg on my face I guess.........They were so small I could not have dreamed they would do so much.
Old 07-30-2008, 04:14 PM   #5
invertmast
its all about leverage.. very little weight way back on the tail does alot of work in balancing.
Comparf Eurosport
1/7 F-14D
