Old 08-10-2008, 04:01 PM   #1
ziggymonster
Default Trouble tracking plz help
I'm having trouble tracking my blades. Can't see the leading edge in flight, but can see the trailing edge. The mark I made on the blade is high on the trailing edge. Is that the same ajustment as if on the leading edge.
ziggymonster is offline        Reply With Quote
Old 08-10-2008, 04:04 PM   #2
Felt
I believe so, basically you need to lower the pitch of the high blade. Regardless if the mark is on the trailing edge or not. If I'm wrong, maybe someone else could help.
Felt is offline        Reply With Quote
Old 08-10-2008, 05:03 PM   #3
Adam T
Right. Doesn't matter where the mark is on the blade (although I and most people apply a stripe of tape that runs the full width of the cord, from leading to trailing edge, top and bottom). Simply reduce the pitch of the high blade or increase the pitch of the low blade.
For big adjustments (large tracking error), you can adjust the short link that runs from the blade grip to the mixing arm. For smaller adjustments, you can adjust the link that runs from the mixing arm to the inner swash ball. Just be sure you think about it first so you know whether you need to make the ling you are adjusting longer or shorter to achieve the desired pitch change.
Finless has a great vid on this in his tech room.
T-Rex 450 with one of them old fashioned flybars
130x with one battery pack
MicroHeli Brusheless mCPx with SR120 Tail, etc.
mCPx brushed, mSRx, and a few planks
Adam T is offline        Reply With Quote
Old 08-10-2008, 05:34 PM   #4
Aussie_phoenix
The only thing I would add is that you need to check the pitch of your blades and mark the bladegrip on whichever one is closest to zero pitch at centre stick (if you are running a straight 0-25-50-75-100 pitch curve). From now on don't mess with that blade, do all adjustments on the other blade (increase or decrease pitch with the control arms).
Hope this helps.
Trex250 Phoenix25, DS410 GP750 5084 AR6110
Trex450SEV2TT 4S Scorp-8 Phoenix45 CC10 Spektrum H3000 MKS-DS95i AR7200BX
CopterX450ProTT 4S Typhoon2218 Phoenix35 HS65MG GP750 MKS-DS95i AR6100
Trex600E 8S 1910H/1Y HV85 5625MG Gy611 S9256 AR7000
Aussie_phoenix is offline        Reply With Quote
Old 08-10-2008, 05:56 PM   #5
Felt
Good point!
Old 08-10-2008, 07:03 PM   #6
ptarp
Also ensure your blades are balanced.
Philip
* Raptor 50 w/TT50
* TRex v2 SE/Align 430XL/CC35/CCBEC/BergRx/GY401-S9257/HS56
ptarp is offline        Reply With Quote
Old 08-11-2008, 12:37 AM   #7
ziggymonster
Default Thanx fellow freaks
She's in the air again and as good as new. The bummer of it all was, Got to windy to hold a good steady hover long enough to sight alone. Usually have a fellow freak sight for me.
