| 600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Hey,
I can't find a jesus bolt (m3x20 socket screw) for the trex 600 Nsp anywhere. Anyone know where I can get one online?? Thanks. |
Sponsored by Visa/MasterCard / Team Budweiser / Trojan Field Rep Donut Connoisseur To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. HELI-FREAK, You couldn't have picked a better place to land ! |
yea but these are fully threaded, the align ones are threaded only like 3 mm from the tip. Does this difference matter when it comes to a Jesus bolt or no?
I searched Align and RC Assurance as well as serveral verndors. The only place I see them is with the main shafts, they provide two bolts. I guess they figure if you are replacing the bolt, you are going to be replacing the shaft too.
I think the threaded ones would be a little weaker adn probably less tolerance, maybe a little more end play.
ty for your input, yea threaded ones would be weaker. Just got a set of main shaft with Jesus bolts from the local shop, they just received them today too, back to the built
#6 |
You can use threaded bolts at a pinch but collared probably better - ALign do a pack containing two blade bolts and two Jesus bolts
John |
#7 |
sweet, ty for the link
#8 |
I can't believe you have to buy a main shaft just to get a M3x20. Align should sell a hardware pack.
#9 |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
You don't, and they do. See John's post above. The part number is H60158.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#10 |
Can anyone verify if the M3x22 jesus bolt can substituted for the M3x20 jesus bolt where the autorotation gear attaches to the mainshaft?
#11 |
I don't know why not. It's only 2mm difference and there's nothing that the extra bolt length can hang up on as the gear turns.
#12 |
Alan, The part that John specifies includes the M3x22s. My only concern is the 2 mm difference maybe enough to inhibit the locking nut from resting in the plastic case(autorotation gear housing.)
The reason I am asking is I am building my 600nsp and my M3x20 will not slide all the way through. I think I may have a manufactoring defect. And during the process of trying get mine to go through I may have damaged some of the treads on my M3x20.So i would like to get a new one. |
#13 | |
#14 |
Yea I noticed that it comes with 2 x M3x22. I guess I can buy the hardware package that John refers to and see if it will work. Thats for the help Alan. Now I need to figure out why my bolt will slide through the mainshaft and the autorotation independently, but not when they together.
#15 |
The autorotation sleeve always gives me fits. It does a really good job of hanging up the threads on the bolt. Once I get it started, I just wiggle it a lot until it starts moving and then continue wiggling until it gets all the way through. You just need to make sure you don't push too hard.
#16 |
Well I'm on vacation in Sea Grove, Fl so I'll have to figure something out when I get home next weekend. I've had this heli for 3 weeks now and I'm ready to get her airborne already.
