Old 08-15-2008, 04:23 PM   #1
peterman1
Default gy240 gyro and s3102 servo help
hello
i have the futaba gy240 with a futaba servo on the tail.. the gyro is mounted under tail boom holder... my problem is I'm getting tail wag..i moved the ball like as close to the servo gear as possible and I'm down to 50% on the gain... i starting to think my gyro is not working correctly or the servo i have is not the correct one to be used with this type of setup... the linkage appears to move freely from the servo to the tail rotor.. i did have a little crash a week ago and i stripped the pitch servo so i replaced the pitch,elevator,and aileron servo with three hitec hs-65mg servo.. the gyro case was not damage... could a small crash damage the gyro... thanks for any help
Pete
too fly or not too fly... what the heck i'm gonna fly
peterman1 is offline        Reply With Quote
Old 08-15-2008, 06:37 PM   #2
roscoe
check for missing or damaged teeth on the belt.
roscoe is offline        Reply With Quote
Old 08-15-2008, 07:01 PM   #3
peterman1
ok will do.. have to head out to work will ck first thing when i get back..thanks for the response
