Go Back   HeliFreak > R/C Helicopter Support > Turbine Helicopters
Turbine Helicopters Turbine R/C Helicopters
Old 08-19-2008, 07:45 AM   #1
davebnz
Default Century Super Gasser...
This is just begging for a turbine conversion. Big, solidly built machine :-)
http://www.runryder.com/helicopter/t453603p1/
Hey Sara, ETA ;-)
davebnz is offline        Reply With Quote
Old 08-19-2008, 08:51 AM   #2
Bell Bloke
THAT IS BLOODY POSH!!!!
Well spotted old lad!
As you say doing your own conversion would be easy.
Bell Bloke is offline        Reply With Quote
Old 08-19-2008, 09:05 AM   #3
DDragon
I would say you're right! If they had that available I'd have gotten one instead of the predator. Love all the milled aluminum.
Cheers, Deron.
Still lovin' it after all these years
DDragon is offline        Reply With Quote
Old 08-19-2008, 02:30 PM   #4
Bell Bloke
Ahh yes but don't forget the Predator is a much more compact size, so I'd rather have the Predator.
Old 08-19-2008, 03:02 PM   #5
Coolice
Hey Guys,
Sorry to put a dampner on things but looking at the frame design it doesn't look like it would lend itself the the Turbine conversion to easily, they seem to be all in one like on the Freestyle which is why that model has not been Turbine'd.
Having said that, on any Gasser model the frames are well spaced apart to cope with the wider engine and so a 44 may fit as an example.
Someones got to try it when they are released.
Ian Contessa
Team Robbe SchluterUK / Midland Helicopters / Align
Coolice is offline        Reply With Quote
Old 08-19-2008, 03:05 PM   #6
Bell Bloke
Chop the frames! And then add your own brackets for the engine.
Old 08-19-2008, 03:23 PM   #7
DebianDog
PM Billme here on the freak. I am sure he helped design it and would answer your questions.
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 08-20-2008, 04:03 AM   #8
davebnz
okay, continuing with this thought of hacking and modifying, how much different is the Condor gasser from the predator ?
Does this lend itself to a the Wren conversion :-)
Old 08-20-2008, 04:06 AM   #9
davebnz
okay continuing with this theme of modifications, chopping and using fine craftsmanship to fit a new power plant (pass me the knockcrometer please ;-) ) , how much different if the Condor gasser to the predator ? More study in the construction ? Does it too like the Wren conversion kit :-)
Old 08-20-2008, 04:07 AM   #10
davebnz
Old 08-20-2008, 05:58 AM   #11
davebnz
sorry guys, net outage here gave the illusion all had been lost..... the bitstream had a disturbance ;-)
Old 08-20-2008, 08:32 AM   #12
Bell Bloke
Predator and Condor are the same structure just longer tail boom and bigger clutch
Old 08-20-2008, 02:53 PM   #13
Coolice
And ideal gear ratio out the box to I think from memory.
Only problem with using a Gasser or Condor airframe as the donor mechanics for the Turbine conversion is the lower rear frame sections are different I think? I've never seen or tried a Gasser to Turbine conversion and so cannot say for sure, but I think the rear frames are different.
Ian Contessa
