Old 08-20-2008, 01:31 PM   #1
Wolfpackin
Default DX6i Trim Tab Failure: Anyone Else?
My rudder trim switch, on the front of the DX6i, stopped working in the direction of right rudder trim.
Unfortunately I did not fully realize this until my rudder trim was clicked way over to the left.
So now I'm stuck not able to fly unless I fix the switch or at least get it back over to center.
Do I access the trim tab/switches by removing the front hex screws and cover or do I open up the back of the radio?
Has anyone had this problem or know if there are any user friendly (servicable) parts inside?
I have a bad feeling nothing will look fixable to me.
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 08-20-2008, 01:36 PM   #2
Penguin
You probably tried this already but I have one finiky trim switch that I have to push down and to the side instead of just pushing to the side.
Penguin is offline        Reply With Quote
Old 08-20-2008, 01:38 PM   #3
RevToTheRedline
I have the same problem as the above poster, doesn't bother me any though.
RevToTheRedline is offline        Reply With Quote
Old 08-20-2008, 01:41 PM   #4
eugenefelisco
Wolf did you try to look at Radioshack if the switch is available. You will have problems if you can't get it to the center.
Blade400,325 radix blades,ds285,ccbec,401/9650 and align canopy,tail stabs, vertical fins and 500 skids.
5 planes,one heli and still growing
eugenefelisco is offline        Reply With Quote
Old 08-20-2008, 01:43 PM   #5
Slyster
To get it centered (for now) you could copy the model to an empty slot. (I would think it wouldn't copy trim settings would it?) or make a brand new model.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is online now        Reply With Quote
Old 08-20-2008, 02:39 PM   #6
Flyemhigh
I did and took it back to the LHS I bought it from and they sent it back to Spektrum for repair. They gave me a loaner until it was returned.
Trex 450se w/65mgs, Scorpion outrunner, Scorpion 60A esc, gy401w/ 9650 on the tail and gorilla paddles .....Raptor 30V2 completely upgraded....Trex 500 w/ hitec servos on cyclic, gy520 on the tail....DX7...Realflight 3.5
Flyemhigh is offline        Reply With Quote
Old 08-20-2008, 04:10 PM   #7
gmd59
I had the same problem...I called Horizon and they said to send it in....I was without the dx6i for about 10 days...
They fixed it with no questions asked.
GD
gmd59 is offline        Reply With Quote
Old 08-20-2008, 04:19 PM   #8
Wolfpackin
Thanks for the responses guys.
I don't have a local hobby store.
And I'm really hoping I don't have to send it back to Horizon and be without a radio for a while. Besides, the last part I returned to Horizon got lost.
So, has anyone taken the front of the radio off?
Ant thoughts on accessing the back of the trim tabs?
Thanks again.
Old 08-20-2008, 04:20 PM   #9
rourkem
I had this happen on my DX7. I managed to "fix" it by pushing really hard in the direction that wasn't working. I did that, plus some wiggling until I was able to re-center the trim. I haven't had any issues with it since.
rourkem is offline        Reply With Quote
Old 08-20-2008, 06:09 PM   #10
GunnyGlow
Ya gotta stop bangin those sticks around mang!!!
GunnyGlow is offline        Reply With Quote
Old 08-21-2008, 01:14 AM   #11
Wolfpackin
Default Fixed It
Yup, turns out it was just a broken arm on the plastic trim tab/switch.
The trim tab rocks a lever arm back and forth, like a seesaw, to actuate push button switches on a circuit board.
One of those lever arms was broken and unable to apply enough pressure to the integrated switch.
Glued it back with CA and all is well.
Old 08-21-2008, 05:56 AM   #12
jhgamer808
Default Front or Back?
So you never said if you fixed it by opening the front or the back. I'm guessing front since that would be most logical right? Anyway,great repair! Anybody else with this type of problem should check to see if theirs is as easy to fix!
jhgamer808 is offline        Reply With Quote
Old 08-21-2008, 07:18 AM   #13
e-bomb
happened to mine right out of the box. i took the back off, and shimmed the rocker with a few pieces of tape. works fine now.
-evan
e-bomb is offline        Reply With Quote
Old 08-21-2008, 10:31 AM   #14
TowPilot
Default a long shot but....
Thanks again.
Maybe you could talk Horizon into shipping you the part and you install it?
Just a thought......
TowPilot is offline        Reply With Quote
Old 08-21-2008, 11:10 AM   #15
HeliMix
Obviously, you now know. There are six screws in the back and the Tx comes apart. Careful if/when you do so. The wires are a little short and you cannot simply lay it open.
Knowing the customer service of Horizon, I would certainly call them if you have trouble in the future. If you feel you can do simple repairs, ask them if they would send you the switch. If not, send it in to them. As you can see, they do a lot, no questions asked. I have been very pleased with their CS.
CX2 | Blade 400 | Trex 500 | RC10 GT2 | Phoenix Flight Sim | MyTube
Mix Design Group (MDG) - www.MixDesignGroup.com
HeliMix is offline        Reply With Quote
Old 08-22-2008, 01:18 AM   #16
killboy
Mine did the same thing on the right stick. Figured out the hole that the trim switch sticks up through was just too small, and not letting it move into clicking range sometimes. I popped the controller open, and used a small file to enlarge the whole so the switch could move further. Put it back together and no problems since.
Best Regards,
Darryl Cannon
http://killboy.com/
killboy is offline        Reply With Quote
Old 08-22-2008, 12:12 PM   #17
MCD
I have had the same prob I just switched the rudder trim button with throttles
don't use that one as often.Thats if you only broke the tab off the other one.
MCD is offline        Reply With Quote
