Old 08-27-2008, 09:56 AM   #1
hawkins221
Default dx7 expo
hi all, in the dx7 menu(swash mix)it is setup for 120degrees but in this menu there is a exp act or inh,what is this for?
and in the pitch curve menu,s normaal,idel1,idel2,there is also an expo,do i use this? how do,s it work,an when would i set it up before i set the pitch or after?sorry just got it yesterday,already flown,its much much much better than my mx12,i really like it,gonna send it to get the new software onit,any tips or adice guys?
hawkins221 is offline        Reply With Quote
Old 08-27-2008, 10:19 AM   #2
BarracudaHockey
I'd turn on the EXP in the Swash menu. Its best to do it before you do your final setup as it will take away a bit of overall throw so you have to up your percentages a bit. It compensates for the fact servos have more throw at center than at the extremes.
The EXP in the pitch and throttle curves is easy to see what it does by setting up a V curve and turning it on and off. With it on you have a very smooth U curve, with it off you have the sharp V. It smooths transitions between the points.
Andy
AMA 77227
Jacksonville FL
BarracudaHockey is offline        Reply With Quote
Old 08-27-2008, 10:27 AM   #3
hawkins221
thanks man! that helps,anymore tips? any will be cool just to help with dx7 setup!what about mixing channels? were would that help?anybody use the mixxing?
