| 700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
First off, I've gained invaluable knowledge from this site and I want to say a huge thanks to HeliFreak for making this hobby (now addiction) lasting and very enjoyable! I rarely post but I feel this could help someone considering a 700E. It's a way for me to share and give back to this awesome community.
--------------------------------------------------------------------------------------------------- I just completed my initial T-Rex 700 electric conversion!! Based on what I was using, I had no idea if it could even work but I was pleasantly surprised! Basically, I had a high power 12s setup for my 600 but unfortunately, I stepped up to 14t and the headspeed was probably too high for the plastic main grips because one of them broke off while in a high hover and the heli violently exploded! Setup: NEU 1910H/1.5Y on 12T 12s 2100mah combo pack (3 x Revolectrix 18C 4s 2100mah wired in series) Revolectrix 15C 2s 750mah pack (for receiver power) Align RCE-B3X 6V voltage regulator 3 x S9451 on cyclic GY611/S9256 combo CC HV-85 ESC JR R921 receiver X9303 2 x Cellpro 10s dual pack balancing charger Sorensen 33V-33A rack mount power supply (Set to 15.7V) Radix 690mm 2000 headspeed at 0 pitch Throttle curve: 70 flat Max pitch 9.5 degrees (That'll go up!) I honestly didn't think it could've worked but it really does! This 12s combo is especially nice because I use these single 4s packs in my 450SE, two for an 8s combo on my 500, and until recently, the exact same 12s setup on the 600. Bear in mind I'm not at the hard 3D stage yet and I haven't fully wrung it out but it's extremely smooth with great power(especially in the first 90 secs) and super light weight. The main drawback is a 3 min flight time max. Even this works well for me though because I have 2 of those 12s pack combos and 2 Cellpro 10s fast dual pack balancing chargers. I always have 3 4s packs charging while flying so even though my flight times are shorter, the packs only take between 9 and 10 minutes to charge up and I only have to wait a few minutes between flights! - This shows that it's possible to easily convert to electric - Perfect CG - Cheap 12s packs!! $186 - 12s packs can be separated for a power Trex 500 8s or 450 4s setup - 3 minute flights but only 10 minute charge times so almost no waiting between flights. - After a full flight: motor temp is very warm, ESC temp relatively unchanged, 12s combo pack is mildly warm - Super light weight and simple - 700 frame helps protect packs much better than any other Trex because they're not mounted in front. I have several 25C 4s 2200 packs that I'll try out sometime soon for comparison. I just wanted to share my findings and unexpected easy success. Hopefully this helps some freaks! Any comments or questions are welcome. Marlon
Trex250: 520/3500G,Trex450SE:NEU 1107H/6D,Jazz40,6s950,65MGs,401/9257,AR6100,Radix325,Superframe Trex500: NEU 1905/3Y,Jazz 55,12s1300,9650MGs,G770/DS520,AR7000,Radix430 Trex600ESPN(Nitro frame): NEU 1910H/1.5Y,Jive80+HV,12s2200,DS610s,760/DS620,R921,Radix600 Trex700E(SK360): NEU 1915H/1.5Y,Power Jazz,15s2200 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ,9451s,611/9256,R921,Radix690 Last edited by marlonm7; 08-29-2008 at 01:08 AM.. |
Interesting, but 3 minute flight times would drive me crazy. Heck 6 mins on my 600E drove me insane having to always stop, get the heli and change batteries. Now factor in charging at the field (which I never did), and i'd seriously throw in the towel. But good luck to you!
Have laser, will travel. |
#4 | |
But in any case, certainly not the setup for you. Marlon
Trex250: 520/3500G,Trex450SE:NEU 1107H/6D,Jazz40,6s950,65MGs,401/9257,AR6100,Radix325,Superframe Trex500: NEU 1905/3Y,Jazz 55,12s1300,9650MGs,G770/DS520,AR7000,Radix430 Trex600ESPN(Nitro frame): NEU 1910H/1.5Y,Jive80+HV,12s2200,DS610s,760/DS620,R921,Radix600 Trex700E(SK360): NEU 1915H/1.5Y,Power Jazz,15s2200 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ,9451s,611/9256,R921,Radix690 |
#5 | |
#6 |
Team Taco CEO
Yes, 4.5C without a balancer, be very carefull. I've seen my share of lipo fires and they were all due to no balancing while charging.
Kevin Don't Taco My Pack, Bro! , Why crash when you can POUND it! |
#7 | |
Marlon
#8 | |
Marlon
#9 |
Yes! The trunk works very well.
#10 |
Wait where's the muffler again?
Oh and btw your nitro is UGLY! No nitro slime anywhere. ![]() Edit: That thing looks sweet. I couldn't give up the smell of nitro but dang man nice job.
(Compass Warp 360 w/Stock Motor (17t) running from a YGE60 governed at 3200RPM by the Vbar Black, sporting MKS DS95 on cyclic and JR3500G on tail) Proud Field Representative for the following To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#11 | |
Darn! I was hoping nobody would notice it was missing! I didn't strap it down properly before my maiden flight and lost it in the weeds! lol Thanks! My unfortunate incident with the 600 is the only reason this even happened. Looking back on it, I'm actually happy because this .90 is yet another level up from the 600 in stability. I'm finding that running 2000rpm on the 690s at 9.5 degrees of pitch on this .90 is about as punchy as the 600E at 2100 on 600s at 12 degrees. So it seems that the power to weight ratio is even better than I was expecting. A part of me still doesn't believe how well this is working. Thanks.... and please rock that 700N for me!!
#12 |
Location: Born in London, Live in ATL, Heritage from Ghana
You are very creative, didn't know the Neu 1910 can take up to 12s.
Thanks for sharing. Robert
------------------------------------------------------------------------------ <<< Ashlyn, daddy loves you more than his heli's, don't mind mummy >>> <<< ..............MA Spectra G (Supporting Made in USA), DX7.............. >>> ------------------------------------------------------------------------------ |
#13 | |
#14 |
Wow is there any modifications to the frame to mount the motor? What motor mount is that?
Nice job. You got to get some larger packs man
Not Sponsored= Not Biased |
#15 | |
Mounting the motor is really the only work involved. This is what you'd need: - A Trex 600E motor mount - 4 x 3mm x 12mm socket head cap screws (to secure motor mount) - 4 x Specialty washers for Trex 600 (not required) - 2 x Home Depot's "3/32 FERRULE & STOP SET" (SKU #7331-526 I believe) for perfect spacing of the motor mount between the frame. It's where the ropes are. - Loctite - A drill (I used a press for the new holes in the motor mount itself) - A ruler I mounted the hard way since the frame was already together before drilling the holes for the mount. I can give you the exact vertical and horizontal spacing if you decide to do it. You will probably need to drill 3 holes in the top of the motor mount if you want to duplicate my setup(including motor). I felt a little uncomfortable using the stock mounting holes because the shaft on that particular NEU motor is short. That meant the frame holes closest to the gears would've been drilled closer to the edge than I would've liked. Once you know where the holes are to be drilled, it only takes a few minutes for the mod. But you must take your time and make sure the holes are accurately placed for obvious reasons. It's not much work and I've already done a lot of it for you.
Trex250: 520/3500G,Trex450SE:NEU 1107H/6D,Jazz40,6s950,65MGs,401/9257,AR6100,Radix325,Superframe Trex500: NEU 1905/3Y,Jazz 55,12s1300,9650MGs,G770/DS520,AR7000,Radix430 Trex600ESPN(Nitro frame): NEU 1910H/1.5Y,Jive80+HV,12s2200,DS610s,760/DS620,R921,Radix600 Trex700E(SK360): NEU 1915H/1.5Y,Power Jazz,15s2200 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ,9451s,611/9256,R921,Radix690 Last edited by marlonm7; 08-29-2008 at 04:42 PM.. |
#16 |
Interesting project, and thumbs up for innovative and creative solutions.
I dont know about your flying style, and subsequent amp draw , but with my own experience of 12S, the 2100 packs would suffer EXTREMELY short life in my use. They would be pushed to burst level at each flight and probably very close to burst into fire.I have used some Evolite V2 2500 packs and they is going well above 70degrC, and is close to RIP after less than 40 cycles. My TP V2 3300 packs is much better, but also they is getting decent warm (+50degrC). My new Outrage 3000 packs is also getting over 50degrC. I cant imagine that a decent powertrain on a 700E would draw less amp, and by that your power setup doesnt make sense to me.
T-Rex 650 CF / Scorpion 4025-630, 12S To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Jive 80+HV,2 x TP 3300 6S V2, Radix 710SB,Super Stubz,Futaba 9451,Spartan DS760/BLS251.Quick UK swash and tail T-Rex 700N, OS 91HZ, Hatori 939, Radix 710SB, BLS 451, 9254 for throttle, Spartan DS760/BLS251, Quick UK tail, |
#17 |
What about using A123 packs?
Perhaps have two packs of 8 cells for a total of 52.8 volts, 2.3 AH. The Cellpro chargers can be set up to work with the A123 cells, and you can charge eight cells at a time.
Custom quad copter, Cobra C-3525/18 motors and ESCs; APC 15x4 thin electric props. OpenPilot ControlCopter board. Futaba 8FG Super 2.4 gHz FAAST system. |
#18 |
I really like the idea; and its amazing that it works. In my experience i found that high series cell counts with lower capacity packs, end up with a very high pack Impedence and the cells end up burning up large amounts of power in heat.
If i was going to do it; i would use 10 cell 4400- 4700mah range. Thanks for giving use something to think about! |
#19 |
great idea , thanks for proving it does work .
you can fly with less than a 3000 ma pack , although i would probably go to 15s with 2100's 3 mins is fine , short for circuits , but more than enough time to bend my mind at the sticks. Thanks for posting , get a balance charger . Jason |
#20 | |
Jason |
| Tags |
| 700, 700e, conversion, electric, trex |
