Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 09-04-2008, 10:23 AM   #1
rfequity1
Default os 91sz with Hatori SB-16FH
I believe this is called the "Todd Bennett Special". Any problems using these together? Is this an ok pipe?
rfequity1 is offline        Reply With Quote
Old 09-04-2008, 10:40 AM   #2
Kinger
That pipe really was created for use with the YS91ST. Not sure if it will mount correctly to the SZ and if it does the motor probably won't run as well as it would on a SB18.
Team Synergy
Kinger is offline        Reply With Quote
Old 09-04-2008, 01:26 PM   #3
rfequity1
Ok. So I went to the LHS at lunch and bought Hatori SB-17FH-2. Will this work ok for OS91SZ?
Old 09-05-2008, 11:30 AM   #4
rfequity1
Can someone please advise me if the SB-17FH is ok with the OS91SZ?
Old 09-05-2008, 11:40 AM   #5
jet22b
On my T-Rex 700N, I am using the OS91SZ with SB-18FH pipe from Hatori. Over 25 flight with this setup and I just love it.
Also check your box and if it say that this pipe will fit the C-Spec & SZ, than you are okay!!!
Hope that help!!
jet22b
My your blades hit smooth air!!
T-Rex 600N Pro-OS Max50-Futaba GY611/S9256-DX-7 System
5 T-Rex 600E in Hangar!!!!!
AMA Member
T-Rex 700N PRO - OS MAX 91SZ
jet22b is offline        Reply With Quote
Old 09-05-2008, 02:42 PM   #6
rfequity1
Hope that help!!
jet22b[/quote]
Yes it does say that. Thanks for your help.
Old 09-05-2008, 08:10 PM   #7
HeliSmith
In my research... It will fit and run on your motor but it isn't optimally tuned for max power on that motor. It is tuned for a lower RPM. You want an SB18FH.
helism th
HeliSmith is offline        Reply With Quote
