Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 60/70/90
Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters
Old 09-09-2008, 06:12 PM   #1
corona007
Default Show me your electronics for Rappy 90
Would like to pic someone brain LOL. Show me your pic's. I can't seem to use the search very well. Or If someone has a link to existing topic.
Thans, Lou.
corona007 is offline        Reply With Quote
Old 09-09-2008, 06:58 PM   #2
USA_1_INK
Here is the setup on my 90se . Just waiting for the Gov. and Arizona Reg , Batt. to get here .
USA_1_INK
ID:	62364   Click image for larger version
USA_1_INK is offline        Reply With Quote
Old 09-09-2008, 07:11 PM   #3
corona007
Cool, Where you going to put the regulator?
Old 09-09-2008, 07:13 PM   #4
USA_1_INK
I am going to put the Reg Underneath where the Batt. is at now . then put the Batt. up above on the tray .
USA_1_INK
Old 09-09-2008, 07:23 PM   #5
corona007
I have the arizona too and thats a great spot I think, But I think I might put my battery (lipo) under the frame. between the landing gear. My 611 amp/display Im thinking on upper left side of frame. Gv-1 and 2.4 on servo tray. Gyro on top rear. What do you think?
Old 09-15-2008, 10:40 AM   #6
Maxime30
Here's mine. Way too many wires!
ID:	62968   Click image for larger version
ID:	62969   Click image for larger version
Maxime30 is offline        Reply With Quote
Old 10-18-2008, 10:55 AM   #7
USA_1_INK
I got my Arizona Reg, And 5200 Relion Batt. , and CY ATGv3 Gov . Just have to give them a test flight .
USA_1_INK
ID:	65999   Click image for larger version
Old 12-29-2008, 11:03 PM   #8
reaaz
Here's the electronic guts in my R90..
Futaba PCM receiver
Arizona heli regulator with pin flag switch (6V regulated & 4.8V to gyro)
7.4V 5000mah relion battery
Futaba 611 Gyro with S9256
Aerospire Multi governor
Futaba S9252 (cyclics)
Futaba S9155 MG (collective)
Not a very attractive layout, but the receiver & battery wrapped in foam (with governor on top) with regulator velcroed vertically behind are very secure & still very vibration protected. Note the Gyro amp is on 1/4" of foam tape
Otherwise, I have also put on a G-force 90 tuner head block, Rocketcity links throughout, Push pull elevator & OS 90SZ-H non pumped with Muscle pipe 5
ID:	74351   Click image for larger version
ID:	74352   Click image for larger version
reaaz is offline        Reply With Quote
Old 12-31-2008, 09:09 AM   #9
LAMAR COOLEY
Default Raptor electronics
corona007,
Check out my gallery. I've got some shots of my raptor electronics.
Regards
Here, when wanted
There, when needed
Everywhere, when looked for
LAMAR COOLEY is offline        Reply With Quote
