| Blade 400 Blade Helicopters (eFlite) 400 Helicopters |
Here is my dilema. I started to install my align 35a ESC in my B400 because I bought the Jazz Kontronics for Copterx and I noticed that the bullet connectors for the Eflight motor do not match up with the Align ESC. Well I took out my Align 430XL motor out of the copterx because I bought a scorpion motor for it.
Here is my dilema. Should I install the Align motor in the B400 or should I keep the Eflight motor and soder new bullet connectors on the Align ESC? Which motor is better? ![]() |
if i'm not mis understanding the align motor is a lower kv . ... might extend flight times for you ?
#3 | |
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. B400 DS285/3400G/401/-8/40Aesc/sonicCNC/CNCframe TwinRexx: 6xHS-65/2xGY240/jfg500/TH2 CH-47D/UH-1H Crewchief/ Mechanic
OK I did some probing and it seems I may have to cut my Align 450 sev2 canopy inorder to get it to fit. If someone can confirm this then I may not switch motors. How much of a pain in the arse is it to soder bullet connectors?
The 430XL is heavier and has slightly more power (350W) than the E-flite motor.
Zen and the Art of Helicopter Maintenance Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.) CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG. T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades. |
#6 |
i guess it depends on how good a soder you are. im sure even if your messy youll be ok
#7 |
Well I just measured the difference in motor sizes with my canopy and even with the wires it will still fit.
#8 |
their not to hard, they should have a hole in the side, just stick your solder tip in it and heat it up then fill it up with solder. then take the wire and heat it up and add some solder to it. then take the bullet connector and reheat it up till the solder inside melts and stick wire in it and remove the solder tip and hold wire steady till solder gets hard
#9 |
got it thanks. I'm going to just change out the eflight motor's connectors to be able to fit the align ESC. Then I will be able to run either motor if I choose. Thanks guys.
#10 |
http://www.youtube.com/watch?v=I_NU2ruzyc4
http://www.youtube.com/watch?v=CT18mxfGRjo Search soldering.. there are more! All somewhat apply.. toghether lots of great stuff
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. |
