Old 09-10-2008, 02:51 AM   #1
blazerk5
Default Trex V2 Tail Rotor
Is anyone using the trex v2 tail grips. I am getting massive vibes with the tail blades on.This is my second one also and the blades are balanced.
Looking it over, the slider links are not centered over the tail shaft with the stock balls. Maybe this is the problem? Do I need longer balls?
Tim
blazerk5 is offline        Reply With Quote
Old 09-10-2008, 02:49 PM   #2
JOMAZQ
all the trex se v2 tails i've seen on a B400 are full tail assemblies.
JOMAZQ is offline        Reply With Quote
Old 09-10-2008, 07:40 PM   #3
blazerk5
Ok. What I just discovered was that the stock grips are now causing the same vibration. All of the parts are new from the boom back. Looks like I am now yet another person stuck with the dreaded tail vibes.
Tim
Old 09-10-2008, 10:53 PM   #4
JohnLund
I've been running the Trex 450 tail hub, and blade grips for a while, nothing except a stronger tail. I ran it with the balls all the way in, and out just enough to make the links level, and never noticed any difference, or vibrations. Just put loctite on the balls so that they stay all the way in, because they will back themselves out until the links are level, though they won't come all the way but still, better safe than sorry.
JohnLund is offline        Reply With Quote
Old 09-11-2008, 07:37 PM   #5
blazerk5
John,
What trex tail is that. I went with the v2. My hub does not look as robust as your's.
Tim
Old 09-12-2008, 12:29 AM   #6
JohnLund
Originally Posted by blazerk5 View Post
John,
Tim
It the original SE tail in gray.
